Hello,
I do not need any help on the structural side of the press. I want to build a 100 ton press but am having a hard time designing/sizing the hydraulics for the press and finding an economical way to achieve 100 tons.
If I use a hydraulic cylinder at 3000 psi I need roughly a 10" cylinder which the price on is ridiculous... If I try to find a pump that puts out more than 3000 psi it gets really expensive. I have read some forums on the frame but no one I have been able to find has had a write up on how they got the hydraulics to work. I want to use one cylinder in the center. It can be air over hydraulic or electric over hydraulic that doesn't make a huge difference to me. I just want it to reach the 100 ton mark and not be more expensive than I could just buy a cheap one..
Thank you for your help in advance!!
