moonlight machine
- Nov 19, 2007
- marysville ohio
A friend road races this thing, 1000cc Honda MC. he had the head off for whatever. when he put it back on it leaked coolant. So he changed the gasket and it leaked again. then he brought it to me thinking the head was warped, can I machine it? The straight edge says it is flat so I look a bit closer. it has helicoils in the head bolt holes. The helicoils are all balled up on the bottom of some of the holes. The head bolts are hitting this mess before they tighten against the head. I guess when He torqued the head the helicoil turned in the head instead of the bolt turning in the helicoil. A bit of anti seize on the headbolts would probably solve this problem. I got 1 helicoil out, not much fun as they are about 1" below the deck. Now here's the problem, where do you get 9x1.25 helicoils? not from McMaster Carr. They must be available somewhere. Does Honda offer them as a repair for stripped headbolt holes? My local dealer is closed till Mon., I guess I'll check with them then. Does anyone know?
