1144 Round Rod - Page 2
Results 21 to 40 of 44
Thread: 1144 Round Rod
  1. #21
    Sep 2015
    66
    7
    27
    There has to be another supplier ther in Vegas. I live in the middle of nowhere and have access to 4 different suppliers who will deliver that for half that price. Granger even lists it for $66.00 for a 1' length.
    As far as machinability, it is really nice to work with. Get a decent carbide insert holder and make sure you have a solid tool post. You should be able to rip through that at around 600 - 900 rpm with a .005 - .05" depth of cut and .01 - .015"/rev feed rate and achieve a really nice finish.
    You will have to play with the speed feed and depth of cut a little in order to achieve the finish you are after depending on how rigid your setup is.
    Trying to make too light of a cut can actually work against you
  2. #22
    Jan 2011
    Fairfield, PA
    238
    93
    99
    1144 is not pre-hardened. Cannot speak for cutting with HSS (except drilling) but, heavy cuts, light cuts, heavy feeds, and light feeds, 1144 does not care.
    I've run feeds from .0005" to .020" IPR and DOC from .0005" to .500", it does not fight back. It will cut at any surface speed. I don't like to drop below about 250 SFM for productivity's sake.
    Not enough clearance on the tool? Too far above center?
    "104 per inch" - Your reading the threads per inch. The feed rate would be around .003" IPR. Your feed may actually be half of that depending on the thread pitch of the cross feed screw.
    Bill
  3. #23
    May 2017
    FINLAND
    654
    139
    299
    20th vote for the idea that you got something else than you ordered.
    Sound more something like prehard 4340
  4. #24
    Jul 2011
    Americus, Georgia
    228
    273
    48
    When you have the stock mounted in the lathe, make a light face cut and confirm that the cutting tool is actually cutting on hoz. centerline. You should be able to see if the tool has been knocked out of alignment.
  5. #25
    Jun 2003
    Mebane North Carolina USA
    6,087
    50
    1572
    Did anyone notice the lathe he is using.....
  6. Likes digger doug, JST liked this post
  7. #26
    Oct 2005
    erie,pa
    7,465
    14123
    3451
    Quote Originally Posted by Mebfab View Post
    "Lathe Shaped Object"....fixed it for ya...
  8. #27
    Aug 2012
    las vegas
    16
    If I can will try to attach a few pictures. Always careful to have cutters on center line. Tried the file test. File only left very fine, hairline, marks on bar.
    Not sure if it is working trying to add two photos, see them in "manage attachments" don't know if they will add to here?
  9. #28
    Aug 2012
    las vegas
    16
    Here are a few more pictures of tool holders I use, KDK. Some inserts, VNMG, VR82, and a small 1/4 inch triangle insert I got years ago and in search of more inserts for it, any suggestions?
  10. #29
    Jun 2001
    St Louis
    16,165
    1242
    2306
    If that shiny section of bar is the supposed 1144, it does not look at all like what I have received when 1144 was ordered.
  11. #30
    Mar 2007
    On Elk Mountain, West Virginia, USA
    1,875
    659
    612
    If "File only left hairline marks", they sent you the wrong stuff.
  12. Likes JST, Dave G., eaglemike, Oldwrench liked this post
  13. #31
    Aug 2012
    las vegas
    16
    Default Having Problems Machining 1144 Round Rod
    Quote Originally Posted by magneticanomaly View Post
    Contacted the seller this morning, they state my piece was cut from their bin marked for 1144. What I might try to do is order a smaller piece from McMaster or Grainger to see if it is similar.
    I saw a couple other suggestions for steel in previous posts. Any more suggestions for a machinable steel that can withstand some friction, heat, not brittle. In other words for general automotive or medium mechanical use.
    Thanks again to all.
  14. #32
    Mar 2011
    Geneva Illinois USA
    4,356
    1675
    1582
    If I had to select a general purpose steel, I would use 4140 heat treated to 20-32 Rc. Very commonly available, hard enough for a lot of applications, easily machined, can be heat treated to the upper 40's, lower 50's.
    Tom
  15. Likes JST liked this post
  16. #33
    Jul 2008
    Ontario, Canada
    169
    54
    Seconding the suggestion of 4140 HT. It is perhaps my favorite steel to turn. It might provide a bit more trouble on a smaller machine than what I use though.
  17. #34
    Jul 2008
    Ontario, Canada
    169
    54
    When you filed the piece, what RPM were you running the lathe at? Is it correct to assume this was on the 2-1/2" diameter mill scale finish?
    Nice new file, or rusty and abused antique?
    If I'm nosing in the right direction, try a good file on a corner of the material with 0 RPM. If the file cuts, material is unlikely the problem.
  18. #35
    May 2017
    FINLAND
    654
    139
    299
    Quote Originally Posted by Sparky961 View Post
    Even old abused antique file should cut 1144. But file will cut even Hastelloy and that has about zero machinability compared to 1144.
    To OP:
    Is it magnetic?
    What sort of sparks you get if you hit it with grinder?
    http://www.scrapmetaljunkie.com/241/...sting-metals-2
  19. #36
    Aug 2012
    las vegas
    16
    Quote Originally Posted by MattiJ View Post
    To OP:
    Is it magnetic?
    The Spark Test and Spark Testing Metals | Scrap Metal Junkie
    When I was finishing a piece a few days back wanted to break the corner, had lathe at around 250 rpm, file would barely brake the edge. The supplier may have gotten the wrong stuff? Who knows.
  20. #37
    Jul 2008
    Ontario, Canada
    169
    54
    There are lots of ways to figure out what you've got in front of you. If you only answer 10% of what people here are asking, you'll never know.
  21. #38
    Mar 2005
    Clev, OH
    273
    41
    79
    Quote Originally Posted by TDegenhart View Post
    Tom
    That's a typo. It should be 29-32 HRC.
  22. Likes TDegenhart liked this post
  23. #39
    May 2009
    Wyoming
    2,742
    5874
    4067
    Quote Originally Posted by todd1 View Post
    ...they state my piece was cut from their bin marked for 1144.
    Yeah, well, what would you expect them to say?
    Invest an hour in your education: pay a visit to a machine shop and ask to SEE a piece of Stressproof bar stock.
  24. Likes digger doug, Matt_Maguire liked this post
  25. #40
    Apr 2014
    san diego
    436
    293
    236
    I use 1144/stressproof often. Never ever came in shiny finish. When I started in a shop 40 years ago I learned about this stuff. Nice to machine, good mechanicals for how easy it is to machine. Case hardens well too. Never ever shiny bar though from the supplier..... Came out of the 1144 bin, LOL.
    I have a bunch of 7/8" round drops about 5 inches or so long. I could send you one in a priority mail flat rate box, and you could see how nice that stuff really is.
  26. Likes Oldwrench liked this post
