Rudd
Stainless
- Jul 30, 2003
- savannah, jaw-ja
My pressure switch failed the other night, the compressor did not shut off, thankfully the safety valve worked as advertized.
So, I need a new pressure switch for my old compressor, which has no unloader, no check valve, etc. I'd like to correct that.
Right now, the switch is set on it's own line coming off the tank, all by it's lonesome.
I'm looking at the Furnas switches like this - Furnas 1 Port Pressure Switches which has an integral unloader.
So I get that I need a check valve on the line to the tank. And it looks like the Furnas switch is to be on the line - at some point - such that the unloader can dump the air between the pump and the check valve.
If it's upstream of the check valve, and the unloader dumps the air, then isn't the switch seeing -0- psi, which would then kick the motor off again?
I see check valves with 1/8" npt taps which mention being lines to unloaders or "control lines" Shorty Check Valve
does the pressure switch (w/ unloader) run off a line from this port on the check valve?
thanks in advance for any wisdom.
