windsormw
- Dec 11, 2006
- The corner of Hill & William
some kinda danger today @ work ........
Hot Damn ! Fellas i am a constructiom Millwright & I do alot of BIG lifts & all kinds od stuff that will make ur blood pump .
I am workin @ a local car plant & its brand spankin new ........nothin in there yet , but we are in the press SHOp & we are stacking their presses . Not to big , 2 800 tonners & 2 1600 tonners .
reguardless , here's the story ........
We are doing GANTRY lifts because the inhouse bridgecranes are only good for 44 ton .....So trucks are coming in & the are holding the 800 ton gantry system ( bunch of trucks )
There are rails that the gantry rides on , real heavy ( reinforced H beams ) & a big dirty stack of em on a trailer .
The wheel says , "she'll pick that stack " ...He says that each rail is 5000lbs a peice & there are 8 of em .
u do the math , 40,000lbs in iron VS a 40,000lb fork truck .
With parameters like that I would choose a different route ........But i am not the wheel , just a Mulewright ..
So i pick er , yup feellin good .....If u have ever brought a rig to capacity , u will take care in everythin u do ( a sudden shot of throttle in reverse can trigger ur rig to tip ) Being rammy with the controls can send her over etc.
I grab this monster load off the truck & all is well ....The ass end is on the ground & i am smooth .
As i am backing up ( away from the HIGH BOY trailer) I am waiting for the green light from my signal man to come down on the load .
Keep in mind i have had this load 5'+ in the air for a few minutes now . All is well , so i thought
This 20 , can boom the mast back & forward much more than conventional 3 ton truck .
I get the green light to come down & as the load comes down the mast it moves the center of gravity forward & the 20's rear wheels are air bore .........
thats a problem .......What do u do ? Split second decision time .....fork truck going over & it ain't gonna be pretty .....
I been in this situation before .....The awnser is down ! No body got hurt , no damaged gear ....a couple rails fell of the stack when the load hit the ground .
Bottom line , the wheel was right there . He knows this system not me & he said grab the stack . As an operator , that will not hold up in court . U are the operator & have the VITO card on liftin .......u don't like it u don't lift . That will hold up in court !
I was complimented on my quick decisions & all agree'd ...It could have been worse
lesson learned !
scott
lesson learned !
scott
