I need to be able to cut a 1" wide section out of a UNSEALED plastic tube such as a hand cream tube, tube paste tube, etc. I need the cut to be very straight and leave no rounded edges. So something with a razor blade would probably give the best cut. I need it to cut a strip about 1" wide out of the tube, so basically something like a pipe cutter where you can cut a piece of pipe off... only problem with plastic tubes are they are very soft and pliable so you can't clamp anything onto the O.D. of the tube to cut it.
