moonlight machine
- Nov 19, 2007
- marysville ohio
My Air Products vis arc thfc 300 rj welder is equiped with the usual Tig torch but also has stick welding cables. They hang under the welding table with my air compressor in front of them also under the bench. So about 1/2 hour ago I'm tig welding and all the sudden there is a pop, sparks, and a loud hissing sound of an air leak...wtf?? So I pull the compressor out and it has a hole burned through the tank! The stick weld cable had a bad spot in the insulation and was against the compressor tank. When I was welding with the tig torch the stick leed had power to it also and was arcing to the tank through the bad spot in the insulation. But how did it ground? It has to be through the power cord as the compressor was not hitting the bench. The hole is only about .020 dia cone shaped out to about .090 Dia. Do I weld it up? the rest of the tank is welded together so a little weld should be ok, what do you think?
