Tightmopedman9
- Dec 6, 2016
I'm trying to make this piece out of schedule 10, 1.5" diameter 321 stainless. Finish is not overly important as I will be welding this to other sections of the same shape.
I would also like a 45º edge bevel at the end of every pipe to facilitate welding.
I just picked up a Sharp HMV mill (Bridgeport clone) with no tooling except for some R8 collets. I have little experience with milling (read: none). I'm wondering what tooling would be best for these two operations. I know that a saw the cuts and a bench sander for the beveling would be faster, but considering the price of 321SS I would like to make the parts as accurately as possible, and use my new mill!
The pipe section is formed by two 12º cuts separated by 18º. I was planning on making a fixture to clamp the pipe at 12º and using a face mill to cut to a depth of .589" over 4", then rotating the pipe by 18º for the second cut.
For the bevel I was thinking about using a chamfer cutter, and since I don't have a rotary table, using the ProtoTrak MX2 to move the bed in a circular path.
My head is swimming with all the possibilities of cutter geometry, number of teeth, type of teeth etc. Optimally, I'd like to invest in tooling that would applicable for a widerange of operations. I see myself milling mostly mild, stainless and AL, with a rare need to exceed .005" accuracy.
