viragocafe
- Mar 18, 2018
The people on here seem to really know their stuff and the mathematic equations required to determine what I need. What I have is a 40x40x25' tall shop that has all this extra height we would like to take advantage of by build a loft that we could use as a large studio apartment / office. I would like to know what it would take material / beam wise and their sizes to make a 40' span down the center supporting the 20' cross members going out to each side of the building. I would consider adding a vertical support or 2 in the center if absolutely required and if it meant a drastic savings on materials and so forth. But to start I would like to try and estimate the project from the expensive end if we were to remain the free spanning downstairs. I was told according to the 2015 IRC for the live load we would need 50psf uniform and 1000psf concentrate with a floor deflection live load of L360, with downstairs being a garage with light manufacturing that is 150psf uniform and 2000psf concentrate. It asked about the collateral loads but I wasn't sure if that was a different term for any of the above info about code weights or not.
I wanted a downstairs height of 15', which would give us 2' of space to build the floor while still having 8' ceiling height at the eaves upstairs. Since we don't have any height restrictions to the floor thickness itself, instead of all the cross member beams meeting perpendicular with metal plates and bolts to the main support beams keeping them on the same plain. We had planned it would be easier to install if we ran 2 main beams north and south on either side of the shop and 1 down the center then stacking the cross beams running east and west on top of the first beans instead of connecting them to the side of each of main support beams and having to drill a 1000 holes with connecting plates. Then we had planned to weld each beam connection along with gussets on each joint to help with lateral loads. I should mention the 2 main beams running north and south 40' along outside walls do not need to be free spanning since they are along the walls any vertical supports required would be out of the way. The 3rd main beam running north and south down the center of the shop would be the only beam we prefer to span the actual 40'. This way the cross members running the opposite direction only need to span 20' instead. Then if absolutely necessary or if a major cost savings adding a vertical support or two down the center of the 40' beam in the middle of the shop. I had thought this might be cheaper by having 3 main beams where only 1 makes the actual 40' span instead of only 2 main beams down each outer wall while each cross member made the 40' span. I definitely need some engineering advice as to what the best design would be as well as the materials it will take to maintain the load requirements. The foundation itself is 6" thick fiber reinforced, while 18" around the perimeter the foundation drops down to 12" thick for the footing.
Even though the shop is a good size with some heavier equipment downstairs the upstairs would basically just be where I have some clean quiet space to do my upholstery work and may be an apartment type setup I could use with bathroom and small kitchen for use from time to time. So I just wanted it set up as a big studio where the heaviest piece of equipment would be a 3-400lb sewing machine, few tables, desk, computer, and etcetera. If possible I would like the loft to be free spanning so that it does not interfere with the shop down stairs. I am hoping even though it is a 40' span that being a lighter duty use would mean that vertical supports in the center could be avoided. I have emailed 15+ engineers all of which have chosen to not reply or bow out being uncertified in Washington. I don't know if that is due to my project being ridiculous or not large enough being a single floor design to capture their attention. For now I am just trying to determine the type of materials that would be required to make a free spanning floor to code so that we can put together an estimate of what this project would cost. Then I can determine if the cost savings are significant enough that it would be worth working around a post or two downstairs in the shop to support the center of the floor.
If anyone is just curious enough to crunch some numbers that be great to help us determine some actual costs of this project overall. If there are any engineers out there interested in a side job I am more than willing to pay someone for their services, please contact me at [email protected]. Once I can determine a cost and all that is involved I planned to talk to the city to pull actual permits. At that time it will have to submit drawings in triplicate with an application that the city engineer can sign off that the floor will support local codes. But beforehand I need to put together a cost by determining what would be involved and which way we would approached the project construction wise to make sure we even have the funds available to take on this task. I am more than capable of the construction, but the math and formulas you guys use as engineers is way over my head and I don't intend to attempt them myself. I know where my expertise lie and I intend to stay in my lane. So I would definitely need some sort of a design / blueprints to follow before we can begin the actual construction to be sure exactly where all the beams should meet and how. But I am hoping someone may be able to help put together a rough estimate for now by letting me know what size beams I will need and how many so I can begin to source supplies and what they will cost.
Thanks for taking the time to read this and thanks in advance for anyone who takes the time to offer any real help. It will be in Everett, WA 98204 if that makes a difference, and city advises we follow the 2015 IRC building codes for an office upstairs and a garage / light duty manufacturing downstairs.
Thanks again, Greg
[email protected]
Thanks again, Greg
[email protected]
