Michael Moore
Titanium
- Jun 4, 2004
- San Francisco, CA
While I've got the table cleared off on my Tree Journeyman 325 (link here) I've been measuring the table/knee/quill movements. As you can see in the brochure photo the 325 is a rigid chassis machine -- what I've got is what I've got, without the typical ram/nod/shake adjustments as you'd find on a Bridgeport-style mill.
What I'm working with is one of those 12" x 4" OD cylindrical squares and a Interapid .0005" DTI held with a Noga jointed-arm magbase. I also used the probe for checking the table flatness.
Mostly, things are looking pretty decent for a 30 year old mill that was used in industry before I bought it.
As I mentioned in another thread the table slots seem to be very parallel to the X axis motion. If the quill is fully extended hand pressure on the end of it results in the DTI just barely moving enough to see so that seems tight. At 7" from center on the left side of the table when probed it is .0003" high on the back "land" and on the +7" (the right) rear side the back of the table is .0007" higher than the front.
Over 6" of Z movement the knee is out .0004" (X) and .001" (Y) which seems very respectable.
When I "sweep" the (centered) table (9.5" diameter circle) the back is .002" higher than the front of the table (with the knee locked). .001" is hit just before table center slot on the left side and just after the slot on the right. That seems like pretty good perpendicularity of the spindle to the table.
Measuring the quill movement is where I'm getting puzzled. On the sides of the square (X axis) I'm getting just a bit over .004" movement over 6" of quill travel. But on the front (Y axis) of the square I'm consistently getting .009-.010" over 6". The top of the square is tilted back towards the column.
I don't see how the quill can be .004" and .009" over 6" of travel out of square with the table when the spindle rotation gives .002" variation over 9.5" in the Y axis and 0 in the X axis.
Wouldn't that mean that the spindle bearing axis would have to be non-parallel to the quill axis? If so, that seems like a problem that would have occurred at the manufacturing stage and would have been caught before the mill left the factory or at least shortly after the mill was installed with the first customer. My Tree manual doesn't have any specs for inspection tolerances but I'd think that anyone who in the late 1980s had just spent $30K or so wouldn't have been to thrilled to find the quill being that far out.
Doesn't this mean that any hole bored using the quill is going to end up being out of square to the table? Boring with the knee would seem to be a work around, but shucks, this is a CNC mill and I wouldn't think I'd have to be cranking on the knee for a precision operation like that.
I'm also thinking that if I had a very long shank EM where the shank and flute diameters were the same and was milling a deep pocket there would be a chance of the shank contacting the upper wall of the pocket before the flutes contact at the bottom (this should only be a problem on one side and not the other).
There are two lifting eyes on the top of the ram. There is a crack (visible, not gaping open) in the bondo/paint on the column where the head casting is bolted to the body. The head casting is located and attached with 12mm x 60mm taper dowel pins, 12 x 45mm straight dowel pins, and M16x60 socket head cap screws. I suppose someone could have yanked hard on the lifting eyes at some point and stretched the bolts (having the body open up like an over-tightened C-clamp). Let's say that happened and originally the table was dead square to the spindle and is now two-tenths/inch high in the back. But the quill is about .0015"/inch out so wouldn't that still be an indication that the quill and spindle axes aren't parallel?
For lots of stuff it won't make a big difference. But if I wanted to bore (with the quill) some bearing pockets at Z0 and Z-6 I think the measurements would mean that the bottom one would be .009" off the intended Y position, and that's not too cool.
ETA: I did both rotate the cylindrical square and check at three different quadrants and also stood it on both ends as well as having it sit on a couple of completely different spots on the table so I don't think the square is the issue.
cheers,
Michael
cheers,
Michael
