Results 1 to 15 of 15
Thread: 4MT-ER adapter
    madmachinst is offline Hot Rolled
    Jan 2007
    Central FL
    570
    Default 4MT-ER adapter
    OK, I want to see if this exists before I take the time to try and make one. I am looking for something that has a 4mt taper on one end and a flange that gets tightened down to my 1 3/4-8 lathe spindle via a huge threaded collar (almost like a collet nut lused on ER collet holder). On the inside this whole ordeal has an angle that accomodates an ER collet and on the outisde the approriate thread for a collet nut. Just picture something that looks like one of those CAT or NMTB tool holders but is in 4MT taper and with a nut for tightening it down to the spindle.
    Brian@VersaMil is offline Stainless
    Mar 2001
    Gaston, Oregon USA
    1,281
    Larger SIP BORING-MILLING machines use a #4 morse taper, and I have er collet chucks for them. However, it sounds like you want almost a custom holder to somehow attach to your lathe with the 1 3/4 -8 thread. Good luck. It certainly can be manufactured, but I'd be amazed if you found anybody who makes something so specific.
    PeteM is offline Titanium
    Jan 2002
    West Coast, USA
    2,965
    MT3 to ER32 collet adapters are commonly available; with a drawbar for the MT3 end. Don't know about an MT4 version, but you could always get a MT3 to MT4 sleeve, chop off the back, check for concentricity and carefully Loctite it together. You'd use a drawbar into the MT3 portion, rather than a spindle retainer.
    RC99's Avatar
    RC99 is offline Titanium
    Mar 2005
    near Rockhampton, Queensland, Australia
    2,595
    Why not just make one of these that I made?? Lathe collet chuck. - Woodwork Forums
    At least then you can use long rod in the lathe
    davycrocket's Avatar
    davycrocket is offline Hot Rolled
    Jul 2005
    UK
    842
    Mad Machinist
    All the way from UK I looked on your US Ebay and straight away found
    4 Morse ER collet holder. Look at Item No 260558753023
    It doesn't clamp onto your nose but the Morse 4 and drawbar should be all you need.
    Just make a 'screw on' cover for the nose thread to protect it.
    Rgds Davy Crocket
    Aug 2006
    Hesperia, SoCal
    3,598
    This didn't take long, allows me to feed 1/1/2" stock through the spindle, which won't happen if you fill it with a Morse Taper. Yup, takes a spanner wrench, so what?
    http://i102.photobucket.com/albums/m...ef/FinitoI.jpg
    http://i102.photobucket.com/albums/m.../FinitoIII.jpg
    I made it on the threaded spindle so it spins dead true.
    Oh yeah, it was fun....
    Bob
    Jan 2007
    Central FL
    570
    Quote Originally Posted by .RC. View Post
    Now that is what I am fantasizing a poor mans accu chuck. Giving me the ability to work near the chuck. Does the collet seat have to be ground? I was just thinking that the collet holder would have to be centered to the taper in order to get a good TIR.
    RC99's Avatar
    Mar 2005
    2,595
    I finish turned everything after I had mounted it on the spindle so it had to turn out concentric... The ER collets are 8 degrees included angle, I just used the compound slide to get it done.... I know it is not perfect, but it seems to work...
    RC99's Avatar
    Mar 2005
    2,595
    ER collet specs REGO-FIX AG
    Aug 2006
    Hesperia, SoCal
    3,598
    Quote Originally Posted by madmachinst View Post
    The OP says, "I am looking for something that has a 4mt taper on one end and a flange that gets tightened down to my 1 3/4-8 lathe spindle via a huge threaded collar (almost like a collet nut lused on ER collet holder)"
    Not sure why he want's to double up on the hold, sounds hard to do and to no advantage I can think of. Screw it on the "1-3/4-8" nose or use the 4MT but not both.
    Re your, "collet holder would have to be centered to the taper in order to get a good TIR," all sorts of stuff hangs off of various D pins and threaded spindles with accuracy as good as the spindle it'self. The MT in the bore doesn't have an edge inherently. The fit to the face behind the spindle threads squares it up and a little care with the treading, combined with the 30° shoulders on the threads to help center it and ground fit to increased diameter of spindle behind the thread, keeps mine accurate.
    Didn't have a tool post grinder when I made mine, so..
    http://i102.photobucket.com/albums/m...ruingstone.jpg
    Worked great, "ZIP" router on tool post, Norton mounted stone, diamond trued.
    Bob
  11. #11
    Jul 2005
    UK
    842
    Just one more suggestion, and you can use ordinary collets if you have any, or buy an R8 set.
    Picture below shows an adapter that I made to screw on to my lathe nose.
    Started off with a ready made nut from an engineering shop. 1 and 1/2" x 8 threads
    Screwed it on nose up against a thick washer , and turned registers to suit my nose.
    Reversed it on nose and bored front face to take a solid disc.
    Shrunk fitted the disc.
    Drilled and bored and turned front taper to accept my 20mm Collets.
    Made suitable hollow drawbar.
    Works fine and allows long stock through the mandrel.
    Rgds Davy Crocket
  12. #12
    Aug 2006
    Hesperia, SoCal
    3,598
    Here the spindle can be seen with a ground surface behind the threads to fit the bore of the collet chuck to
    http://i102.photobucket.com/albums/m...huckdrawer.jpg
    And here the blued chuck is being ground to a close fit
    http://i102.photobucket.com/albums/m...eronastick.jpg
    Bob
  13. #13
    smdubovsky is online now Cast Iron
    Apr 2008
    MD
    458
    Sounds like what you're looking for is an ER40 chuck that fits your lathe spindle mount and not really the MT4 inside.
    But, there is a guy on ebay selling new Hertel ER40-MT4 chucks for ~$50. I picked one up for the tailstock on my lathe. The nut alone is worth almost 1/2 that. It has a tang, so you've have to cut that off and fab some sort of drawbar mount (just weld a nut?)
  14. #14
    Apr 2008
    MD
    458
    Found it. Search for "Hertel HMT4ER40318" item # 310202385313
    Checking though my history, I offered him $58 and he accepted. Try lower
  15. #15
    Aug 2006
    Hesperia, SoCal
    3,598
    Quote Originally Posted by smdubovsky View Post
    Once I'd decided on what to me seemed the optimum for my 1-9/16 spindle bore, I began watching ebay for bargains. I was looking for TG 150 and I was the only bidder on a new in the box TG150 Dapra mill collet chuck with the orphan NMTB45 taper, $10. I used the chuck for my dimensions and an accurate taper guide while the expensive nut with the extractor spring was what I was after. The rest I had in my shop. I was satisfied with the "pay" I earned the day I made it.
    Anyone that might need that new 45 taper collet chuck body can have it for the postage.....
    Bob
