Long Tom
Stainless
- Aug 21, 2011
- Fiddlefart, Oregon
I have a job offered to me that involves machining several aluminum castings. One of them is a bracket for mounting a fluid pump. It weighs about 15 lbs. In short, I will be grabbing it by its "small" end, likely in my 10" 3-jaw Bison, machining the "big" end, then flipping it 180 degrees to grab the machined big end to in turn machine the small end.
The big end will be machined to result in a 10" OD "ring" about 5/8" deep. Put another way, what I will have to grab is a clean, round, machined feature, about 10" OD, with a depth-of-grab of around 5/8".
My question is this. My plan is to EITHER cut soft jaws for my 10" 3-jaw Bison to grab this, OR to use a chuck that came with my lathe but I've never used: a 10" Buck Adjust-Tru 6-jaw. Important: the Buck has fixed jaws, so soft jaws are not an option.
This is an out of balance load for the chuck. The part will also be protruding from the chuck face about 12". So, it'll put some forces on whatever is grabbing it.
Is this a good application for a 6-jaw or would i be better off making steel soft jaws for the Bison 3-jaw? I simply don't really understand the pros/cons of 6-jaw chucks.
This would be ongoing work with some significant volume so whatever is the best way to hold these things, is what I want to do.
Thank you!
Thank you!
