Have you looked at it with a loupe?Also, is there any option to post a larger image? Not sure if you can see the spots in my linked image above or not.
I can't tell by the pics if it's impurity or inclusion or what. If you have any more material it would be interesting to take some skim cuts and see what it looks like at .010" steps.
its your coolant- some types make black spots on aluminum
If the OP is indicating the lighter colored areas, I've seen that many times on aluminum alloys and especially brass and bronze alloys when machining.
I too have always wondered what that is. It's almost like some weakness in the base material that shows up on the finish, or softer areas from poor heat treating. The shapes are usually crystalline in shape.
Sometimes they are large like the ones in the photo and sometimes they are smaller.
Couple suggestions. When you take a picture of a part, turn the flash off, otherwise you get a ton of glare, like you did. Also, try not to post it using Botophuckit. I don't need to load a bunch of spam along with your picture.
Did you wash the part off? Reason I ask, there's something in our water here, don't know what it is. But if I swish a part off in a bucket of dish soap, and then throw it in a bucket of water, I need to pull it out and blow it off immediately, or it starts growing little spot that are a bitch to get off.
This looks very familiar. From the look of it these spots are all on the threads am I correct ? I cut tons of threads in 6061 and see this often, they are actually small tears in the material. I have tried different inserts and speeds, feeds, holders and can minimize it but they still happen. I use good quality domestic material for all my jobs and still get this. I don't see it in harder grades of aluminum.
Perhaps you can post some closer shots of the threads and someone can solve this problem
Make Chips Boys !
Ron
Notice
