I have a new-to-me Dake/MEP cold saw that I've been trying to get dialed in. It started out as a unit with power downfeed and such. However, I believe it was run into the ground and then resurrected. Hopefully, it will turn out to be a good tool that I can rely on for years to come.
Anyway, it has dovetail ways that the head travels on. I have adjusted the gib several times to get rid of some vibration that I'm experiencing. I've been able to get some smooth cuts without vibration, but it seems like it's pretty bad now. I've tightened the blade, the vise... I can't figure out why this thing wants to shake while cutting. I've been cutting some 1.5" aluminum round stock. It has a nice finish whether or not it vibrates. I believe the blade has 240 teeth. However, it vibrates in a way that makes me think it isn't a speed/feed issue.
If anyone has any pointers as to where this vibration may be coming from, please let me know. I will probably play with the gib a little more and take a closer look at the holding surfaces of the vise. The round had a small flat milled into one side (for indexing purposes), so I'm pretty sure that it was being held securely. If anyone can offer some advice for this thing, please let me know. Thank you for taking time to read my post!
