90 degree magnetic drill press
Results 1 to 8 of 8
    Apr 2008
    Pattison, TX
    80
    Default 90 degree magnetic drill press
    Anybody know whether someone makes a 90 degree magnetic drill press? I know it'd have to have a heck of a magnet to get that side load covered, but we've got plenty of room for the magnet: If I can't find something like this, we'll just put an angle plate up and attach the magnet to that, but the fixturing will have to get a little nuts.
    Jun 2007
    New Zealand
    2,661
    28
    Quote Originally Posted by dwilliams35 View Post
    They do exist, but I can't remember the brand name - If it comes back to me I'll post it
    Apr 2007
    NE Oklahoma
    12
    Milwaukee makes magnetic drill presses. The one I remember using we used for drilling semi truck frames and it also had chains to help support it.
    Dec 2000
    Bremerton WA USA
    10,633
    40
    4048
    Jun 2007
    New Zealand
    2,661
    28
    I remembered ....
    The brand is Hougen, and I found a US outlet for this model on the web at http://www.ohiopowertool.com/p-256-h...ll-hmd115.aspx
    Is this the sort of thing you have in mind?
    Attached Thumbnails Attached Thumbnails hougen-right-angle-mag-base-drill.jpg
    Mar 2004
    Edison Washington USA
    10,136
    848
    4703
    I thought he was talking about a mag drill that drilled at 90 degrees to the magnet holding direction.
    And I have sure never seen one.
    The Hougen is a low profile drill, most of the majors make one of that style. It isnt as tall, but its still the same relationship between drilling direction and magnet as any other mag drill.
    Seems like if anybody made a 90 degree mag drill, it would be somebody like Nitto-
    http://www.nittokohki.com/tools/prod...lls/index.html
    But they dont either.
    Me, I would either clamp, or just tack weld, a big hunk of 6" x 3/4" angle on, and mag to that.
    Apr 2008
    Pattison, TX
    80
    Quote Originally Posted by Ries View Post
    Yep, Im looking for the 90 degree to the holding direction as you say: Ive never seen one either. We've got a heck of a lot of holes to drill in this thing but there's really not any surface to speak of to "clamp" to: I'm sure we'll just end up building a fixture to do it with, but its going to be pretty labor intensive to set it up.
    Thanks, guys. It was worth a shot.
    Jan 2008
    spokane
    855
    5
    83
    How many holes? What dia.? How deep? What material - I beam, angle or ? Is this a field job? Are you on the ground or hanging from a ladder? Do you want your holes taped, sloted or ? Talk to me
