C
C.M.
Guest
I am trying to repair a trumpet who's valves are shot ... ie oversize. Too much clearance. My plan of action is to add a few thou of nickel plate to the Monel pistons and to open up the mating brass cylinder. Apparently the ideal clearance between the parts is about half a thou, 3/10 's is perfect. I've considered honing the cylinders but can't find a hone to go down to the approximate 5/8's diameter. I'm thinking now that an expandable reamer might do the trick. I'm not sure how accurate the final size would be and I'd like to control the tolerance to +/- 0.0001. Finish is important, so I'd almost certainly hand lap the piston into the cylinder. Problem is of course, I need to accommodate the piston into the cylinder which means going over size in the first place but not more than say 0.0002. Just measuring a roughly 5/8's hole that is about 4 inches deep - through hole mind you, so it's 2 inches from either end - is a challenge. My telescoping gauges from China are junk and even with a good set, that transfer measurement ain't going to be +/- 0.0001 accurate. Any suggestions ?
