allloutmx
Titanium
- Mar 6, 2013
- Rochester, NY
Im quoting a job that spells out a 500-1000 phonographic finish on two sides(round part with two flats). I would like to stand the finished turned blanks upright in the vice and use radial chip thinning to remove the bulk of the material. Part is 1.00" in dia and the flat finished at .500" centered. Im not sure how I will achieve the finish requirements by side milling. Are there special cutters to serve the purpose? Would ramping down the wall suffice? Material is 17-4. qty 2000pcs. Only other idea is to lay them down in the vice and do half at a time with a face mill.
Thanks In Advance!
Thanks In Advance!
