This has had me scratching my head for months.
Up at my shop I have some solar panels mounted on the roof. I have some large, high current capacity batteries being charged thru a charge controller. Nothing fancy. I have a pair of good panels (don't know name brand) I also have a set of the 3 panels harbor freight sells (kinda weak outut)
I have the batteries setting on a thin rubber sheet on a concrete floor out of the way. They are spill proof batteries in steel cases. Actually, what I have are twelve 2 volt cells. I make two sets of 6 and wire them in series to make 12 volts. I am charging the two 12 volt sets from the solar panels and charge controller.
That part works fine. As much sunshine as we've had recently, I could lite up Frankenstein!
Here is where the anomaly begins. I have a nice 12 volt DC/AC modified sine wave 5000 watt inverter. Didn't know about the sine/modified sine thing when I was shopping.
I have the battery banks wired parallel feeding the inverter. Works great. The digital readout on the front of it shows 12.50 volts as the thing is powering some big fans in the shop today. Probably 2 amps draw on the fans. I even run a TV and another electrical powered tool.
The fans are old. Mounted on steel pedestals. Both fans have ran for a couple of years since I got them with no indications of trouble. I usually run them off of regular 115vac right out of the wall.
My shop floor is concrete. I have quite a few sheets of 14 gage hot roll steel laying singly around on the floor- cause that's the easiest way to store them at the time. Foot traffic keeps them more or less rust free.
So, lets get to it. The other day I finally got serious and hooked all this panel/battery/inverter stuff up and was going to use it. Things all in order and I plug one of the fans in. It fires right up. It is setting on the steel sheet on the floor. Later on it is in the way, so I kinda skid it off the steel sheet and onto the DRY concrete floor..... instantly I hear the motor slow down as I drag the base across the concrete. I let it stand up vertically and the motor speeds up to normal.
I thought I had a loose wire inside the fan motor housing and investigated. Nothing. Fan is running right along when I need to move it again. As soon as I started shuffling the base around on the floor, the fan stuttered and slowed down and all of a sudden the inverter has an alarm and starts beeping and shut off it's output. I am just sure I have a bad wire, so I redo the investigation. Nothing.
Reset the alarm on the inverter and it comes right back to life. Plug the fan back in and turn it on. Runs fine. Now, I am gonna try some tests. I put the fan back up on the steel sheet and wrestle it around to try and make it do the thing it was doing, but nothing.
I leave it there on the steel. I grab the other big floor fan and plug it in.... setting on steel. Fires right up and runs fast and smooth. Drag it off the steel floor onto the concrete- instantly it shudders and slows down and the inverter alarms and shuts off.... the voltage readout on the inverter stays right where it was at.... not like it was shorting out and putting a big load on the thing.
Never any sparks from anything where it touches the floor. Nothing to indicate something was shorting to ground or whatever.
So, next test I start both fans on the steel and let them run.... grab a big pair of jumper cables and ground them to each other..... nothing.... not a wobble or shudder. Take a little volt meter and touch each housing....nothing on AC. Didn't try DC.
Next, I take one out on the concrete and let it run without moving it around to make connection with the floor as previously. Wiggle the other one on the steel....nothing. Drag it out to the concrete and instantly both of them shudder and slow down and inverter alarms out.
I have big thick sheets of steel welded together for a driveway. Laying on a fine gravel base. I take one fan out there and set it down and start it. It runs good. I wiggle the fan around on it's base and it starts shuddering and the inverter times out. Reset the alarm and set the fan down nice and easy trying not to make a good electrical contact. It's running good.
I take the little analog volt meter and touch the steel driveway and touch the fan base... it instantly acts like some reversed the voltage and it stops immediately!!!! No sparks at the point of contact of the test leads. No movement of the analog gauge! Nothing! As soon as I let off it starts back up and runs.
I walk in the shop door, grab that other fan off the steel sheet on the floor, scoot it over to the concrete floor and as soon as it touches..... zzzztttt~ they both shudder and stall and the inverter alarms out.
Damndest thing I ever seen. I wish I had a movie camera so I could document this stuff.
To recap, dry concrete floor... the inverter is insulated from the floor, but it isn't grounded to anything.... setting on rubber, too. The fans can set next to each other on steel floor inside the shop and no issues. Set together on the steel driveway outside..... stall out. Lift one up and they both start running. I have even grounded one fan to the inverter case to see if anything happens- nothing.
I got both these fans as basket cases as far as the wiring goes. They run together just fine plugged into 113vac setting on the concrete floor or the steel floor. Things only go to hell when running off inverter power. I thought maybe I had the neutral and "line" switched and that could be the problem, but dont' really thing that is it. I never get shocked touching them now or before....
I am stumped. Hope to hear some good guesses.
