mwierowski
- Feb 11, 2018
I bought a used Bridgeport that came with an Acu-Rite III DRO. Recently the X axis has started randomly zeros itself and will stop displaying any change in movement on the X axis. If I turn the DRO off for a bit and then back on, the X axis will operate normally again for a few minutes and then start acting up again.
I swapped the scale inputs on the back of the DRO and the issue continues with the X axis display but using the Y axis scale. The X axis scale seems to be working fine when plugged into the Y axis input. So this leads me to believe that both scales are operating normally and the issue is with the DRO unit itself.
Since the Acu-Rite scales seem to be okay, I am looking at replacing the DRO with an Acu-Rite 200S or VUE. From what I can tell all the features of the two seem to be identical. So besides the physical appearance of the two systems are there any other differences between the 200S and the VUE? Pros and Cons of either one?
I called Acu-Rite and was told I can order an adapter cable for the older MS 6 pin connector to the D9 connector. What I haven't been able to find is is the resolution of the current scales. I am hoping I can locate a part number without having to remove the scale itself. Does anyone know where the part number on the mini-scales are located? I haven't been able to find any identification numbers on the two scales on my mill. Not sure if they rubbed off over time?
If I cannot determine the proper resolution of the scales, when setting up the new DRO what should I use to set the scales? Just guess and then check for accuracy and adjust if the DRO doesn't display accurate measurements?
Thanks in advance for any help and insight,
-Mike
-Mike
