Adhesive work holding.
Results 1 to 18 of 18
    Mar 2011
    Denver, CO USA
    11,362
    41
    4806
    Default Adhesive work holding.
    Thread for advise and experience, and input on adhesive workholding materials and methods.
    Seems like a fertile field for discussion.
    Mar 2011
    Denver, CO USA
    11,362
    41
    4806
    First question...
    I want to make a ring from 3/4 thick steel, 7.500, 6.000id.
    Seems if possible, glueing it to an aluminum sacrificial back plate and turning it would be the way to go to ensure concentricity.
    Would that work?
    Sep 2015
    210
    12
    89
    A 4-jaw chuck on the lathe would do a better job. Hold it by the I.d.(can use a 3-jaw) turn the o.d., then hold the o.d. with a 4-jaw and dial in concentricity to do the bore.
    Dec 2014
    Arizona
    167
    34
    23
    Are you gluing the steel plate to the aluminum back plate just to hold your work(I assume)? Is the 6" bore cut prior to gluing? If the bore is there prior to chicking why not chuck on the ID assuming your using a lathe? Yeah the glue would work of you want to face and bore, but take it easy on speeds and feeds. For a part like that I wouldn't do it. Instead you could center drill a 60 degree countersink and press it to the jaws or a flat faced arbour deal live center or turn in between centers,machine OD, then re-chuck on OD and machine faces and ID bore. Or chuck on OD, machine bore, re-chuck on ID and machine OD. That is assuming your using a lathe, but you could do it all the same way on a mill with a lathe chuck.
    Mar 2011
    Denver, CO USA
    11,362
    41
    4806
    Clamp forces will distort the ring.
    Clamps will interfere with indicating the surface being clamped.
    Oct 2005
    9,563
    16668
    4876
    Quote Originally Posted by Miguels244 View Post
    I turned lot's of ring this way....you develop some work arounds as an
    apprentice, as well as feel.
    Feb 2013
    Madison, WI
    673
    870
    418
    Lighten up the clamping pressure and take lighter cuts. Or you could make it from thicker stock and part off.
    I wouldn't think you could hold onto it well enough with an adhesive to allow you to turn it. I've used a fair amount of double sided tape and some super glue for cutting various woods, plastics, and small metal parts. They work great but the material needs to be soft or you need to to take light cuts.
    Dec 2016
    Kentucky
    127
    22
    38
    If curiosity drives you to try I would at the very least run the tailstock up to "catch it" if it did come apart. From what ive seen of the process none was over about 3' in diameter and it was solid not a ring so a lot more surface area.
    As AARONT said make from solid and part off. Ive done some similar for spacers for bearing and the like.
    Mar 2011
    Denver, CO USA
    11,362
    41
    4806
    Thanks.
    It still seems to me that clamp forces would distort the part.
    It also seems seriously wasteful and expensive to make a ring like this from a solid, and I can’t find DOM that size.
    Thanks for the answers.
    Back to the topic.
    Double sided tape and cyanoacrilate seem to be the adhesives of choice.
    Any others in use?
    Dec 2008
    New York
    8,152
    2165
    First question...
    Would that work?
    had a steel part using hot melt glue to aluminum block did my machining and part was slightly warm so i take it to a sink under cold water and it falls apart. temperature difference with a brittle glue you often get no warning on bond failure
  11. #11
    May 2009
    Canandaigua, NY, USA
    2,434
    102
    924
    I mostly use adhesives for grinding, but everybody should be aware of this stuff- Aquabond Technologies > Home
  12. #12
    Dec 2008
    New York
    8,152
    2165
  13. #13
    Mar 2007
    Milwaukee
    339
    261
    159
    Gluing a part to a mandrel is a necessary step for some parts, ive done it. Not for production, for a few one off's yes. Perhaps there are other ways, a fast paced project requires creativity.
    The part was a paper thin labyrinth seal for a jet engine. There was no way to hold the part with out distorting it,jawed chucks distort work. We only roughed with chucks. Turbines require many thin walled parts held to very small tolerances. We would do what ever it took to get a part round within tenths.
    Very light cuts and a negative raked tool did not move the part. I used thin CA glue and soaked the part in debonder to get it off.
    I am curious if there are better glues that would work better than CA. Something that you could use heat to release, and dip in a solvent to get rid of the residual glue.
  14. #14
    Feb 2001
    Redwood City, CA USA
    4,508
    118
    668
    For CNC profiling, I've held sheet against a sacrificial aluminum plate using hot-melt glue. It holds fine, but cleanup is a PITA. The best solvent I have found is kerosene, but it turns the glue into slimy goo. I have also held sheet onto MDF board by covering the part with wide strips of blue masking tape on the part and on the MDF, and then sticking the tape layers back-to-back with superglue. The part comes off fairly easily with a knife or chisel, and cleanup is a breeze. With the masking tape trick, it's a race against time before coolant soaks into the MDF and wrecks the bond. Ideally, you set the DOC to just break through the metal, and not the second tape layer, so as to protect the MDF from moisture. However, given MDF thickness tolerances and clamping, it is hard to keep the DOC in the layer you want. You have to be careful to avoid wrinkles or overlaps in the tape layers.
  15. #15
    Aug 2015
    Illinois
    805
    666
    335
    Two questions regarding the OP's application:
    Will the adhesive have sufficient shear strength to allow a reasonable depth of cut?
    Will the heat generated during turning and boring degrade the adhesive?
  16. #16
    Jun 2006
    Near Seattle
    4,350
    2352
    1067
    I have personally had OK luck using CA (superglue) to hold an aluminum part to a mandrel. Here are the gotchas:
    1. Both parts must be clean to get the glue to set.
    2. It takes a fairly long time (8 or 12 hours - I did overnight) for the glue to cure enough to be useful.
    3. You need good fitup.
    4. Your mandrel/holding plate, etc. needs some kind of holes for acetone or other solvent to get the glue to dissolve it. Otherwise it will take an insane time to get it apart. In my case the entire assembly had to sit in paint can (closed) of acetone over a day or two.
    5. It's a bit of a pain to clean the glue residue off.
    But yes, it can and does work.
    For the described task (part is flat) I wonder OP wouldn't be ahead to make 2 flat sacrificial sheets and sandwich the workpiece between them. Clamps hold the sandwich bits with righteous force, but need not actually clamp the actual workpiece. I would think this would be a job for a face plate.
  17. #17
    Aug 2008
    near Cleveland
    759
    34
    89
    Consider clamping to either a faceplate or a chucked and faced slug or plate.
    My experience with using adhesives to hold a part was limited to grinding custom carbide drills on two sided tape- it worked but was not extremely precise-more art than science.
  18. #18
    Jun 2016
    Iowa
    50
    Sorry not much experience w adhesive workholding, but to the OP's question how to machine a thin wall ring. Would pie jaws work?
