I need to make around 1000 holes, varying diameters, but say 1 5/16" as a for instance in 1" and 1.5" plate. We'll be plasma cutting the 1" blanks out and probably torching the 1.5" blanks. Tolerance is 1/32 on diameter and location. Material is 44W, fairly run of the mill (literally) mild steel. In the 1" I can plasma cut the holes but at 1" can't hold the tolerance. There are four parts involved, each with several holes, parts are typically 8"x8". I'd make simply jigs for the drilling
Equipment for making holes (in addition to the plasma) is a radial drill, gear head drill press and a vertical knee mill. There's a good selection of large hss drills but if there was a silver bullet i'd consider buying it
I can make a hole, but I lack experience making volumes of them in plate this thick and in larger diameters so am unsure of what approach would be best. Cycles times start to matter with this volume. I'm interested to hear what approach you guys would take. Would you plasma cut then ream? drill the entire hole (no plasma), regular old hss? pilot hole? slugger drill? other crazy assed ideas?
thanks for any advice you can give
thanks
thanks
