NodecoMachine
Cast Iron
- Sep 7, 2011
- NJ, USA, Lebanon
I have a dozen or so "Dies" coming up that need to be finished post machining. They are made of 4140 HT and will be coming off the machine with somewhere around a 32 Ra. I'm just looking for advice on how to finish these holes economically. Last time these parts came thru, I spent probably an hour per part . Other info would be the holes are 1-1/4" long and have a 6 degree taper included approx 15/16" of the way thru the hole. Also the holes will range from 1/4" to 1-1/4" thru. I ended up using flapper wheels with grit ranging from 120-400 before finishing with emery in the last batch but the thru holes were much larger. I think around 4".
Thanks in advance.
Scott
P.S. I also have another batch of dies coming up that are much longer (5-1/2") and need 18 Ra finish with size range of 3/4" to 3" thru.
Thanks in advance.
Scott
