Ken Villars
- Aug 29, 2014
- California, USA
I have a DeVilbiss Pro 4000 vertical tank compressor (6.5 Hp, 60 gallon tank). It's been a good compressor, and I've had it for about ten years or so. In the past five years, I've been using it quite a bit - in fact I rely on it. In the past year, the pump has started to act a bit iffy, with oil lightly seeping at various places, and more and more oil in the tank when I drain it. I have also had to replace the one way check valve three times, at decreasing intervals. It seems to me to be time to repair or replace the pump.
I don't think I have time to learn how to repair the pump, though I might be able to find parts for it. A replacement pump would be about $400. The pump on this unit is a small aluminum two cylinder, single stage model, I think. It has a fairly small and inefficient air filter.
I've thought about buying a new, similar compressor from a box store, but from what I've researched, they aren't lasting for people more than a year or two, even with folks who aren't using them as much as I am (I fill the tank at least one to three times a day up to 125 psi, on average, with some days seeing quite a bit more use).
My decision, as I see it, is to either spend $400 for probably another five years or so of this type of usage (if I can locate a new pump), or try to find a really rugged industrial unit that may well run for decades, if maintained properly. If I spent the amount I would for a new compressor (say approximately $1000), maybe that would be a good idea?
I am not currently set up for three phase 220v power in my shop, but it is on the plan for the near future. Ideally, a single phase 220v solution would mean I wouldn't have to wait on that project (or have two large expenses back to back); but I won't reject three phase if that is the best way to go.
I'm not opposed to looking at used industrial units (pumps or complete compressors), but my budget is fairly firm, and I need to make sure I get a unit that will last and last if I spend that much.
I'd appreciate opinions or advice on this.
Thanks!
Ken
Thanks!
Ken
