air compressor outside? +/-
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Jun 2006
    Spokane, WA
    559
    97
    Default air compressor outside? +/-
    Greetings,
    Just got a full-industrial rated 5hp compressor. It is a big honker and will take up a lot of shop space. An option which just occurred to me is to pour a slab outside the shop wall, build a weatherproof shed and check oil an air filter once a month.
    1. In Spokane, WA, it is colder than a mother-in-law's-kiss for six months a year, down to zero occasionally.
    2. What other problems will there be?
    thnx, jack vines
    Sep 2006
    Abingdon, VA
    3,042
    3869
    2374
    I've had my compressor outside on a pad for years.
    You may have problems with moisture in the tank freezing and plugging your line.
    Dec 2003
    Red Mountain, SE WA.
    263
    Keep mine outside in lean-to. We get down to -10 here. No problems after 10 years. Just do not let it get rained on
    Nov 2006
    Kentville, Nova Scotia
    20
    My first compressor was set-up in my unheated garage. When the temp. was down around zero it would trip the breaker when trying to start. I suppose I could have switched to light weight winter oil but I could also forget to change back to reg. weight oil in the 80° weather of the summer and have a melt down.
    I would just lean the Bernz a matic against the crankcase of the poor ole Quincy for 15 or 20 minutes and then throw the breaker when I needed air in winter.
    Nov 2001
    WAPELLO, IA USA
    6,425
    29
    1814
    in cold temps you may have to put in lighter oil.... or burn up the starter regularly. I had a compressor in the cold during a remodel project and had this issue - it will work, but would be better heated.
    Dec 2003
    grand rapids mi. usa
    439
    For cold weather, a small light bulb in the enclosure will work great to keep the oil from getting too thick, bottom vent the enclosure so the heat will stay near the top.
    Small fan connected to the pressure switch to operate the vent fan while the compressor's running will work great for air circulation
    The PO of my old house had the well freeze up at least twice a year, when I bought the house I put a 25w light in the well house and with no other changes it never froze up in the 19 years I lived there.
    If the shops constantly heated, and the enclosure is right up against the wall, install a vent to circulate warm shop air through the enclosure
    Ken.
    May 2007
    Wellsville, Kansas
    89
    7
    9
    Default Use oil pan heater
    I placed a small "stick-on" silicon oil pan heater under the crankcase of our outdoor compressor. It's worked great for 10 years now. The heaters were avaiable in 2 or 3 sizes at the local farm supply type store.
    May 2007
    Golden Valley, NC
    430
    I've got a length of heating tape permanently wrapped around the crankcase. It's got a built-in thermostat, so doesn't need any attention. They're generally used to prevent freezing of above ground water well pumps.
    Paul
    Aug 2004
    Brisbane Australia/NW USA
    67
    You're going to miss the comforting sound of that compressor chugging away, to say nothing of it starting up unexpectedly when you're standing right next to it.
    Nov 2004
    WI
    4,549
    361
    1004
    Years ago, I had a compressor in the unheated attic of my garage.
    One really cold day, the line to and/or the pressure switch froze up.
    The compressor never shut off. The pressure guage needle was bent over against the top of the guage.
    VERY scary event.
    Be Very careful of that possibility.
  11. #11
    May 2007
    Golden Valley, NC
    430
    Didn't you have a blow-off valve on the tank? They can be adjusted to just above the cuttoff pressure, and should have a capacity(FPM) greater than the compressor can pump.
    Paul
  12. #12
    Jun 2006
    Houston Texas
    1,534
    38
    Quote Originally Posted by PackardV8 View Post
    Greetings,
    thnx, jack vines
    My 5hp Quincy sits on it's concrete pad outside the shop, but I have the 80 gal horizontal tank and all of the electrical inside the shop. No compressor noise inside, yet the tank is right there, easy to blow down if needed.....pg
  13. #13
    Feb 2005
    8,202
    11091
    9105
    The big downside to a compressor outside is the noise that people complain about, we had one outside, a 10hp, not the quietest thing, but not too bad, no problems for months, then a lady stopped by and complained that her 90 year old grandfather could hear it 3 blocks away, but only at night when he took his hearing aids out.
    She called the Codes [email protected]@holes, they came knocking the next day, they said not after midnight, 2 days later another Codes [email protected]@hole showed up, not after 10p, 2 day later another codes [email protected]@hole showed up at 7:05pm and gave my second shift supervisor a criminal citation, he had to go to court for violating a codes order. 3 days later 10 keystone cops(codes [email protected]@holes showed up at noon) and said it was too loud.
    I asked "so what is the law?", how many decibles at how many feet, and the keystone cop(they all had black spandex shorts, tight longsleeve sweaters, with seude elbow patches, and pleated leather shoulder pads, in 6" high letters across their back it said CODES), said it doesn't work that way. Moved it inside, too much hassle with a bunch of power hungry idiots in an anti-business town.
    2 days later the same keystone cops show up and complain that our outside lights are too bright and to remove them, so we did, and now that that whole area was dark, the gangbangers hungout and we got tagged at least once a week, so now everytime we got tagged because now it was dark, if it wasn't painted over by 5pm we got fined.
    The worst part about the compressor is we were less than 50 feet from the RR tracks, with mulitiple crossings, but the train operators never got fined for blasting their horns at 2am.
  14. #14
    Nov 2005
    N E Florida
    1,996
    169
    A lot of AC compressors have oil heaters wrapped around the bottom of them. If you know someone in the AC business you could get a heater from an old compressor and make it fit your pump. Not sure what voltage they run though.
  15. #15
    Jan 2005
    The Netherlands
    5,233
    213
    1171
    another advantige of putting a compressor outside in the colt is less water in the air When freezing no water at all
    Peter
  16. #16
    Mar 2005
    Hamersville,OH
    342
    BobW...Ever consider having somebody kick that fellas ass for him as he was climbing out of his car?Put those gangbangers to use! Make sure you get it done right the first time that way there is no second time !
  17. #17
    Dec 2006
    CANADA
    Ontario
    977
    83
    141
    I moved my compressor ouside last year and haven't had a problem. It is in an enclosure and not having to listen to it in the shop has improved my sanity.
  18. #18
    Jul 2006
    Webster, MN
    687
    9
    I've had my 5hp two stage out in my unheated pole barn for almost ten years. In that time, it's burned up one drive belt (pump too cold, motor keeps spinning) , froze up the tank check valve, froze up the unloader valve and tripped the start circuit thermal overload numerous times. My solution has been to remove power when I'm not there to watch over it. WWQ
  19. #19
    Nov 2004
    WI
    4,549
    361
    1004
    Exclamation
    Quote Originally Posted by pgfaini View Post
    Paul
    The blowoff valve is on the same fitting as the pressure switch!
    So, if the fitting freezes up, so does the blowoff valve.
    VERY VERY Dangerous possibility!
  20. #20
    Oct 2005
    tulsa,okla
    791
    7
    FWIW- when you pour your slab, isolate it from the building so that vibrations are not transmitted into the building. If you do decide to enclose the area completely, it will need a means of cooling such as a fan on a thermostat with louvers and make-up air because it will get HOT during during the summer. The dealership I used to work at ,our compressor got so hot it tripped and fired the fire sprinkler system! what a mess!
