beckley23
Titanium
- Feb 19, 2003
- Louisville, KY, USA
I have an Alliant 2 Hp, variable speed mill , mn 42VC circa 1984. Several months ago, I don't use it much, the head got noisy and continued to get worse until I decided that it was time to tear it apart or this head was going to self destruct. I figured the usual bushing problems, what I found was much worse.
The fixed motor sheave half that's next to the end bell, lost its key and set screw, and the bore wallowed out from 25mm(.9842") to 25.5mm next to the belt to 26mm+ next to the end bell. In addition the key way is 7mm, a non standard size from what I can tell.
The boss in the picture is 48mm(1.890").
I am contemplating a couple of different repairs;
a) clean up the bore and make a split sleeve insert leaving as much of the keyway intact as possible, a friend has suggested silver soldering the sleeve in place, and reassembling. I would size the bore for a light press fit after soldering.
b) bore the existing hole out past the existing keyway and make an insert, with new keyway, to press fit in the sheave. Attaching the insert positively to the sheave is presenting some problems, plus the special keyway is another issue.
Pros/Cons any body.
Before you jump on me, I have contacted High Quality tools, and REM Sales about a new sheave. REM Sales referred me to Sharp Industries, who thus far, has been unresponsive. The "Catch 22" stituation is they want part numbers, I don't have a manual, and apparently they don't either, although Sharp has to cross the Alliant to their machine.
Harry
Pros/Cons any body.
Harry
