proFeign
Cast Iron
- Oct 2, 2007
- Santa Barbara, CA
I will preface this by saying this is probably a stupid question:
I recently bought a near-industrial grade paper shredder finally after several cheaper ones have broken on me due to cheap-*** construction even on what should have been reasonably good machines.
Anyway I am serious about keeping this thing lubed since the government-grade really fine shredders say all over their warnings online (just looking in the jewelry store online - those shredders typically run $1200+ even for the "desk models" and the most expensive one I saw was $24,000 [really]) that they require frequent oiling or they won't work.
So I've been using Starrett Instrument Oil on it for the past few months since I got it and this has worked great AFAICT but I was wondering if something locally available like RapidTap (I have some) will be OK for it? It's a metal cutting fluid so I just wonder about using it on something like this. Probably fine but I'd rather just use the right thing. Tuf-Glide is good stuff but too thin for something like this where I think the paper would mostly just soak it off (lots of powdery sorbents generated) during use.
I have used Hoppe's aerosol on my older shredders but they're not kidding when they say no aerosols in there - even minutes later I got a nice big pop explosion that almost blew the lid off my cheapest shredder from the relay (presumably) kicking in with trapped isobutane or whatever other propellant they use. Easy to get beautiful coverage with an aerosol like that but not going back down that road. Sometimes I shred stickers and the like, folded into carriers to minimize blade exposure to them, but oil isn't a bad thing I don't think.
Any suggestions on shredder oils? I am a big fan of Moly-Dee for lasting, high quality lubrication on tough jobs, but I always clean it off taps and rotabroaches right away, since the sulfur in it seems to attack some metals and so I don't want to go to a sulfate on this since I really can't clean it off or control it very well in the slot of the shredder. Is RapidTap an acceptable option? This is probably a stupid question but I'd be really interested in seeing what other people have to say if anyone has found the solution. The machining cutter blades are stamped steel of indeterminate grade/composition/coating (no TiN on this one) so a light machine oil seems like the best thing but it might be able to handle a bunch of other stuff.
