aloris/ dorian vs. knockoffs
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Apr 2009
    northwest nc usa
    17
    Default aloris/ dorian vs. knockoffs
    I just purchased a new lathe with a no name quick change tool post. One of my lathes has an Aloris CA and the other a Dorian which is too small for this new lathe. I wanted to outfit it with something that would use all the CA toolholders I have. Is a good used Aloris toolpost better than a new Chinese one or is it really worth the bucks to buy a new Aloris?
    Jan 2007
    Massachusetts
    5,105
    642
    1015
    You could split the difference and buy a Dorian CA. I have one and have been buying the cheap Chinese toolholders for http://www.tools4cheap.net and find they're working just fine. I don't know what the Chinese toolholder itself would be like, but the holders fit the Dorian correctly and tighten right up.
    Ebay could be your friend here.
    Sep 2006
    Dickson, TN
    1,719
    45
    74
    You could buy a KDK - that would give you one of each - then you could do your own comparison and report to the forum which one is best for the work you do.
    Apr 2009
    519
    14
    The only difference I've noticed is returning to zero if you are using the carriage to drill, with an MT taper attachment for instance. The Phase II won't return dead on always needs to be checked.
    Otherwise I like the phase II
    Feb 2006
    South Carolina
    346
    39
    Aloris uses a sliding gib to lock the tool holder . The new Dorains switched to the piston type lock. I think the sliding gib is best.
    Jan 2007
    Massachusetts
    5,105
    642
    1015
    Quote Originally Posted by Kallam View Post
    Dorian has many different models now. Some are piston, most are sliding wedge. If their website didn't suck so badly you could probably see this.
    Mar 2009
    Brunswick Oh USA
    4,256
    4302
    2495
    Ive got an Aloris on my 20 x 80 American that is very repeatable, but I really like the Dorian on my Sheldon lathe. It's a QITP 30 so it holds 4 tools and indexes every 15 deg. Plus it's very repeatable. Several on this site have said they would never buy a Dorian because of what they did to Aloris, but they never said what happened. Anyone know?
    Ray
    Jan 2007
    Massachusetts
    5,105
    642
    1015
    I'd like to know what happened there too. I don't like to give money to worms. I had done some searching on Google but failed to find anything.
    Mar 2009
    637
    14
    I just bought a piston-type Yuasa CA, as I was searching for an Aloris but got tired of all the ones on which I bid going through the roof. Not wild about the piston design, but I have liked other Yuasa products I've used in the past, and at least for less money than a no-name import my new-to-me lathe won't be dead in the water anymore.
    I, too, would like to hear this rumored Dorian story that has been hinted at here in the past. I almost wound up with one if their stylish red knobbed tool posts, but wouldn't be happy if after the fact I had to use something made by an unscrupulous company.
    May 2009
    Mays Landing, New Joisey
    570
    154
    139
    Does anyone have any experience with the tool holders made by Matthews Precision that are being sold on Fleabay?
    10 year guarantee they state. I looked up Matthews Precision online but could find no company going by that name.
  11. #11
    May 2009
    570
    154
    139
    The story that I heard on the Aloris/Dorian problem is that some people who worked for Aloris copied the design then changed it just enough to get a patent.
    That is the short story, as told to me by the guy from the company that I buy my machinery from. The long story is a lot longer than that.
    While what the workers did was "legal" it is still theft in my eyes.
  12. #12
    Mar 2009
    Brunswick Oh USA
    4,256
    4302
    2495
    Quote Originally Posted by flutedchamber View Post
    Isn't that what Bardons and Oliver did to Warner and Swasey? Might be wrong, correct me if I am.
    Ray
    By the way, that's exactly what Milwaukee did to my patent on a hole cutter. Same concept except add on a couple teeth. Easy to do, once you've seen it done.
  13. #13
    Jun 2006
    PA
    545
    13
    28
    FLuted Chamber,
    The company you want to contact is Quality Machine Tools. They sell a line of equipment called Precision Matthews. It is the same company selling on Ebay. The owner is Matt Nadeja. He's a good guy to deal with and stands behind the tools he sells.
    I've bought some regular straight BXA and CXA holders from him and they worked well. They're not as hard as the Aloris or Dorian, but for the price, I can't complain. The fit / finish on the holders that I bought was very good. I don't own an imported tool post, so I can't comment on them.
    btm
  14. #14
    Mar 2004
    Colton, WA USA
    698
    12
    14
    As an HSM I'm satisfied with my Phase II wedge-type tool posts. The tool holders often need a slight bit of tune-up; but, for the price I'm not complaining.
    I've heard complaints about the set screws being soft; but, they've never been an issue with me.
    At the time I was buying, Travers had the best price. It has been a few years, now, and I've not done any comparisons in the meantime. You might want to check around for sales.
    Orrin
  15. #15
    May 2009
    570
    154
    139
    Thanks for the info BTM.
    I'm looking for a knurl toolholder for my CA series Dorian. I can't see spending almost $150 for something that I will use maybe three times a year. Used units are hard to find in the CA size.
    Again, thank you for the tip. It's a very nice website.
  16. #16
    Jun 2006
    PA
    545
    13
    28
    Fluted Chamber,
    I've noticed on the imported knurl tools, that the knurls are usually junk. The toolholder is probably fine, but you'll want to throw out the cheap knurls and purchase a decent USA made set of knurls from MSC or any other industrial supplier.
    Good knurls aren't cheap, but they make a world of difference in the quality of knurling that you'll get on your finished part.
    I don't know what the knurls are like from Quality Machine Tools. I'm just basing the above info on other imported knurlers that I've seen.
    btm
  17. #17
    Mar 2008
    Reno, Nevada
    511
    16
    26
    Hell, isn't that what ALL the Asian clone manufacturers are doing to KDK, Dorian and Aloris. Except I don't think they bother with patents they just compete with cheap prices. It's completely beyond me how people working in a manufacturing industry that's being gutted by imported products actually buy imports themselves
    If someone doesn't want to spend the money on new USA tooling, with some patience you can find reasonable prices on used tools.
  18. #18
    Aug 2009
    Nevada
    1,699
    187
    462
    We have a couple of doloris quick change tool posts. No problem except sometimes the stud loosens with the top nut. I have bought some chinese tooling and then it hit me. I can buy all the chinese tooling for alot less and have marginal results and why am I making American parts on chinese tooling. If we all accept lower quality tools then our standards will suffer. I try like hell to steer clear of chinese tooling and knockoffs when I can. I even feel guilt for wearing a pair of chinese levis pants
  19. #19
    May 2009
    570
    154
    139
    Quote Originally Posted by Langanobob View Post
    That is very true...most of the Asian clone is not bothered by patent infringement. BUT...when a fellow American steals from you it hits a lot closer to home and raises MY ire a whole lot more than some company 10,000 miles away.
  20. #20
    Dec 2008
    Orange, CA
    179
    7
    Except the patents have long expired in those cases.
