Hi all,
I'm hoping one or two of you may be aquainted with this antiquated but very useful piece of kit in my workshop!
It's a 1964 Churchhill gear hobber as already stated. I've been using it for 6 months with no issues, but now I think something deep in its bowels (and Jesus are they deep and ineccesable!!) has gone wrong.
I did my usual set up procedure and proceded to "touch" the hob on the O/D to do a touch-cut, to make sure everything was ok with my set up as I usually do. I then let it run its cycle and checked the marks left for verification.
The first thing I noticed when I came back in to the gear shop to check how things had gone, was instead of a 2MOD 8 deg helix, I had something around 4 deg (approx).
Of course I checked and double checked my settings (which are good) but somethig else has made me believe there is an inherent problem with my machine - I'm hoping that it's maybe a common problem that someone has a quick and easy answer to!
The thing is, this particular model has a "P.I.V" - or positive infinately variable gearbox, so I adjust the cutting feedrate on the run - I noticed that since this set-up problem, when I alter this feedrate it alters the angle of helix aswell - this is obviously not right!
The helix can go from almost vertical at one extreme to about 2/3rds of the required angle at the other end of the spectrum.
Is there anybody here who is familiar with these machines?
I'm fairly new to gearcutting in general, and only do it occasionally as part of my job running a shift of maintenance engineers - and the service guys have quoted me £3000 to have a look and put it right, now thats alot of money right now
Thanks in advance
Mark
Thanks in advance
Mark
