will gilmore
- Feb 6, 2007
- New York City
I need to put a 1/2" npt thread in some 1" plate at a 30 degree angle (from vertical). The plan is to fixture the plate at the angle, make the hole with a 23/32" annular cutter, then threadmill. I can fit 3 at a time on the table. No tool changer.
Sound reasonable?
Annular cutter: https://empirerigging.com/hougen-23-32-x-2-12-000-series-annular-cutter-12223/
I'm planning on gripping the shank in a ER32 collet. I'll program a stop between each hole to make sure the slug is out.
Sound reasonable?
