rockfish
Titanium
- Aug 27, 2006
- Munith, Michigan
I've run into a few details lately, made of 6061, that have parallelism and perpendicularity called out to within .0005 on aluminum details...........and wondered how you address this situation??? While I have ground a few aluminum details using 3M double faced tape, this is not a fun procedure. I had tried using green wheels, as suggested here on the forum before, and they didn't work at all. I finally resorted to using the same wheels I use to grind steel and used liberal amounts of cutting oil to keep from loading up the wheel. The biggest problem I had, actually, was removing the parts from the magnet. The tape I have sticks like crazy, and you run a serious risk of damaging both magnet and part trying to remove them.
So........what do you do ???
Frank
Home
Frank
Home
