The spindle on my Barber Colman 1 - 1/2 gear hobber (table top hobbling machine) uses a pair of 15x32 mm angular contact bearings. My spindle has about 0.005 inch end play, so I assumed the bearings were worn out or the adjustment was off. After taking it apart I am puzzled by the arrangement.
The bearings are not worn out to extent of 0.005 inch play.
The installation is odd. Unlike the angular contact pair on my mill (or any other angular contact pair I am familiar with), which has an adjustable lock ring to set the preload, this installation has a sleeve between the bearings that the inner races are snugged against, which prevents the inner races from being adjusted, and leaves the 0.005 inch endplay.
The bearings are high precision so I am puzzled that Barber Colman would use such expensive bearings and then have an installation with so much play, especially in a machine that is advertised as being able to cut as fine as 250 pitch gears, which has a tooth height of 0.009 inch. 0.005 inch play with a 0.009 inch cut would render the part unusable.
Before I start modifying parts, does anyone have any thoughts on the problem?
John
John
