Results 1 to 6 of 6
    Ray Behner's Avatar
    Ray Behner is offline Titanium
    Mar 2009
    Brunswick Oh USA
    2,206
    Default Anyone here make U-bolts?
    Looking for 1 5/8" inside dia. x 3 5/8" oal. 9/16" rod size. First 1¼" to be 9/16-12. Must be 4140 or better? Need 4 pcs.
    Ries's Avatar
    Ries is offline Diamond
    Mar 2004
    Edison Washington USA
    7,097
    Portland Bolt.
    Round Bend U-Bolts | Portland Bolt
    made in USA, really high quality, easy to work with, and they will make whatever you want.
    Jim_Lou's Avatar
    Jim_Lou is offline Cast Iron
    Jan 2012
    Belleville, Illinois
    309
    Portland Bolt looks like a good pick. You might also try St. Louis Spring. They make U-bolts for clamping axles and leaf springs. That might be too small for them.
    LEAF SPRING SUSPENSION
    bjorn toulouse's Avatar
    bjorn toulouse is online now Stainless
    Dec 2007
    N.E. oHIo, USA
    1,316
    Ray, these guys are local, give them a shout. Truck Service, Inc. - Ohio
    They do u-bolts.
    Rex
    Timw is offline Stainless
    Nov 2005
    N E Florida
    1,821
    A good truck shop will have straight blanks that are threaded on both ends and they will have bending dies for most common shapes.
    I have seen them heat the centers in a forge and bend and have seen cold bending with hydraulics.
    If you do go to a truck shop try to watch them do the bolts and other spring fabrication. It's amazing how simple their processes are. They can take a flat piece of spring stock and punch, bend and/or forge it into custom shapes. Then heat treat it when they are done! I always loved to wait on the items I was there to get so I could watch them make them!
    Ray Behner's Avatar
    Mar 2009
    Brunswick Oh USA
    2,206
    Thanks for everyone's response. Some couldn't and others wouldn't, unless it was a big order. I found them at LMC Truck Parts in Lenexa, Kansas.
