To ad something to the writings above
It is a Dutch lathe but no longer supported by Hembrug
They only do hard turning machines now
For support you can contact
http://www.schinfa.nl/pages/handelhome.html
But I don`t know if they give support abroad
If someone knows please let me know
There are many models made
1000rpm 2000rpm and 4000 rpm versions
Hardened bedways like Greg discribed but also soft ones
Feeds just on the apron and on the apron and cross slide
With and without gearbox for the feeds
Threaded or camlock spindle
500mm or 750 mm between centers
And then the rare M model Greg has
About the 2 gears the tumbler reverse mechanism employs on the DR1
Nowadays they are redisigned with Nylon or delrin or other plastic gears
Modul 2, Z=22 and 15mm wide with 2 bearings 61901zz each
So if you can get some plastic gears M2 Z=22 and minimum 15mm wide you can make your own
The DR133 has different gears BTW
you need a gear Z=127 to make inch threads when you have a metric
leadscrew and vica versa(Like for most lathes. 1 inch is 25.4mm 25.4x5=127)
Standard collets are B25 (not B24 Greg mentoined) but also not available new any more
But working with an adapter you can use any collets as long as it has a MT4 adaptor (If it has the MT4 spindle of coarse) and you make your own drawbar for it
Peter
