hello, to all.
i joined here hoping someone could help me out. i have a lincoln sp-125 plus. the thing worked awsome. It was stored in my dads basement on the floor and the city storm drain backed up and put 3in of water into the machine. I tried to use it the other day and this is what happened.
First. the wire would not come out. i took apart the motor for the wire feed and cleaned the rollers. it fed the wire like a champ. when i tried to weld, it would go about 1 inch and the whole machine would shut down. wait 5sec. and do the same thing. the wire speed and volts worked though. after a couple tries of this the wire would not feed again.
could it be the liner? wire feed motor? transformer?
can someone please help me out or put this in the right forum if this is not the correct one.
thanks,
mike
thanks,
mike
