JHorton15
- Jul 16, 2014
- Zionsville, iN
I recently picked up a 2' Bantam press. Everything seems to work well except the depth control at the rear shown in the second photo. While trying to adjust the depth by turning the hand wheel in some spots it is almost impossible to turn. Inside the cylinder welded to the end of the threaded rod is a steel piston used to center the rod inside the tube. It looked to me like it may be dragging on the walls. So I machined a piece of nylon of slightly bigger OD and a little bit taller to try and guide the thread as you turn it. It really didn't make any difference. Has anybody had experience with this type of press? How hard was it to rotate the hand wheel and adjust the depth?
