Motorsports-X
Hot Rolled
- Nov 22, 2014
- Texas
Does anyone know of a valve that opens with pressure, closes when flow stops, but may still be under pressure? (maybe closed is activated by a pressure spike?)
see if i can explain this simply... A stem would go into the balloon. The stem is 2 inches long and at the bottom of the stem would be a plate. (imagine this as a closed container that can hold pressure) so when pressure comes into the front side of the plate (between the ballon opening and plate, surrounding the stem) it pushes the plate back, and therefore the stem, opening a passage into the balloon and filling it. once the balloon is full, the system should close, but there will still be pressure on the front of the plate trying to push it back.
I guess there could be a spring of some type in back to help it, but whats important is that as soon as it hits a critical filling point (meaning flow has stopped) the valve closes automatically.
now picture 4 or 5 balloon in a row fed from the same source, all stems piped together, one may not be quite done filling because its a different size or type of rubber etc. Hence the reason there is still pressure on the first balloons valve though the cycle isnt fully completed.
there cant be any kind of external activator, or moving device external to the valve. (that would be it too easy) it all needs to be enclosed. size doesn't matter as long as it works. it can have mechanical movement inside the valve if necessary.
any ideas? did i explain it badly?
