Hi.
I have a Pinacho manual lathe, which makes a rough/poor surface finish only when i do fine cuts (1/10 mm)or below. When doing roughcuts (1mm and over) the surfacefinish is as should be.
There is no play in the carriage and I just tightened the cross slide without any improvements. The main spindle bearings seems good as of the suppliers spec (checked)
It leaves this surface both with manual and automatic feed.
Any suggestions for further checks/ improvements?
Thanks!
Jørgen
Thanks!
Jørgen
