Perhaps I am just ignorant in this area, but how can true ball screws be used on a manual knee mill? If feeding by hand won't there be a problem there?
Vs. using the conventional way if half but and acme lead screw?
Like a lot of things the details matter, a circa 5TPI - 5mm pitch ball-screw won't readily back-drive on most sensible Bridgeport cutting, drag from its self, the thrust bearings and a power feed is plenty to keep it still. If your trying to use big cutters in hardned materials diffrent story, but keep things sensible and use good sharp cutters and i have no issues with mine in hardox 450 at 45Hrc ish till im feeding so hard its near screaming at me. The zero backlash is so so so good,
Now if you stick something stupid in there like 20mm pitch then yeah back driveing is probably more of a issue. But std 5TPI - 5mm sure works good for me and these days ball-screws are cheap, really cheap! If i bought a new Bridgeport tomorrow it would be the first thing i would swap out along with ditching the R8 spindle for a QC30 one.
On a mill larger than a bridgeport with more power - higher cutting forces it would be a different story, retrofitting a horizontal with them could well be a bad idea too where you have seriously large high torque cutter engagements.
IMHO its something you need to try and use and then make a informed decision on, not just apply logic too.
Ball screws back drive.
The acme gives you more ability to contro forces.
Unless you have some sort of active control a ball screw could break your wrist.
I am one of the guys that can't figure out why so many people want to "improve" a knee mill. They are NOT a rigid machine. They don't make good CNCs and they are not real good at most of the things they do, but they do it all. JR
youtube video, or it didn't happen!!!!!In my case yes i run mine part the time under Linux cnc control, its not a vmc, more just like another usefull function to add to a bridgeport, last week was profiling a 11 tooth 520 chain size sprocket, couple of days ago it was a nasty and repetitively shaped pocket cut out. CNC means you don't need a horizontal rotory table and you can drive - mill any shape you wish, + the power feed like functions running in MDI mode gives you. Its great to buzz key ways in whilst your doing something else etc.
Huh? I have ball-screws on my BP. I can use all day by hand. Still have all my wrists and fingers.
Bullshit!!!
Notice
