I have some work pieces that have a shaft turning on a C932 bronze bushing about 3/4 ID and length. I found an off-the-shelf bushing that is the correct size, and unlike previous pieces, actually has a good press fit and should stay in place during operation.
The bushing is designed for a .750" shaft, but after pressing into place, the shaft will not go into the bushing and the installed ID is .745"-.746". The shafts generally measure out at about .749", so I would like to get the ID of the bushing to .750"-.751" diameter.
The quickest and easiest way to do this, and give me a good smooth, round surface, would be to press a steel ball through it to size.
My question is - how much do you resize per pass at this diameter? I know the material expands back a certain amount, but I doubt you should resize in one shot with a .751"+ ball, or would you? Do you enlarge a material this size in .001" increments? More? Less?
Having never actually done this, I would like some advice on the matter.
