dale71
- Nov 13, 2006
- indiana USA
How do you tell if a bandsaw blade is tensioned too tight or not tight enough? How does everyone tension their blades?
Thanks in advance.
Thanks in advance.
Fellow blade plucker here.
I've learned by trial-and-error what the correct tone is for various blade widths.
I'm not a musician my any stretch, so I can't tell you what note.
This calculator and tone generator is rather interesting and may be of use to you:
Thien Audible Tension Gauge for Bandsaws
Thanks in advance.
There is no hard and fast rule by which the correct blade tension can be obtained. In general, tighten new band saws just enough to do the work without twisting or wandering in the cut. After they have been used a little they will have stretched slightly. Then readjust the tension to take up this slack. Blades 3/16" or less require less tension than 1/4" or 3/8" blades. This is due to the fact that narrow blades have less metal in them and require less tension to hold them in line while cutting is being done. Too strong tension, which is unnecessary, will wear the rubber wheel tires.
Correct tension on the saw blade can only be applied through experience on the part of the operator. It is better to err on the side of too little tension than too much, since heavy tension is detrimental to the bearings, the band saw and the wheel tires.
Notice
