Bill D
- Apr 1, 2004
- Modesto, CA USA
For a horizontal bandsaw should I just use the widest blade the machine will run? For a vertical saw the narrow blades allows tighter turns but for a horizontal seems like the wider blade would be stiffer and less likely to break or flex. Of course a wide blade takes more force to twist through the guides so there is that against wider blades then needed..
Bill d
Bill d
