Cole2534
- Sep 10, 2010
- Oklahoma City, OK
How much force should I be able to apply to a horizontal bandsaw blade?
In reworking my bandsaw I got curious about how much pressure I should be able to supply to the blade so is there a good rule of thumb for this? The blade is 1", 8-12 pitch and the main materials are 4140 or 6061, everything from thin wall tubes to 3" solid rounds. the hydraulic pump will develop ~650psi and it has a 4" bore cylinder with a 1" rod so in theory I could develop about 7500lbf at the cylinder, but with the ratios involved would likely be about 1/5 of that at the cut. The blade arm casting itself probably applies 250lbf to the blade just by it's weight.
Any ideas?
Any ideas?
