steelie1955
- Nov 16, 2012
- Midlands, UK
When I started at a new job, about a year ago, I noticed an old bandsaw with the blade running the wrong way.
The guys there said it had always run that way, and they hadn't realised that it was running backwards.
They did moan about how often the blade came off the wheels, which stands to reason because the drive wheel is pushing the blade through the job, instead of pulling
I lifted the cover of the drive wheel and saw a metal arrow rivetted to the wheel (denoting rotation) and was quite surprised to see that the machine (a Wespa) was indeed going in the direction of the arrow.
My question is: is there any advantage to having the blade go in this unorthodox direction, or has the machine been wired up wrong and the 'easy fix' was to turn the rotation arrow through 180 degrees?
