CaptnBlynd
- Oct 12, 2015
using 316 stainless steel 1/16" ( .0625")bearing balls. I have designed my racings at exactly .0625" space for the balls. To allow for imperfection, I feel like I should spec to .064" +/- .001" for the racing area. Does this sound right?
I have designed a device with .015" clearances as a standard throughout. It may produce some heat but nothing "hot to touch". Is there a rule of thumb for expansion? I'm thinking this is a complex formula which I will likely just have to avoid by direct prototype and see if it locks up when hot. Any advice on figuring expansion and clearances?
A few hundred individual parts. Nearly 50 individual magnets. All whirling around with 1/64" clearances. Designed by a retired tech, not an engineer. The work needs precision to the point where I am farming the work out because my blind self just can't get that anymore. I was trying to simulate an imaginary cosmological event and it turned into an alternator. Have you ever found yourself wondering "Why do I have such weird hobbies?"
