Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Rstewart is offline Hot Rolled
    Jun 2006
    Huntsville Alabama
    620
    Post
    I am working with .060" SS and I calculated the bend allowance to be around .286" for a 90* bend.
    Ok that was easy! Now actually putting that formula to work is what is driving me crazy.
    I am working with a .010" tolerance. I have a really good Brake. Just two 90* bends, which I can and did figure out the correct deminsions.
    I would like someone to educate me on how to apply the bend allowance formula.
    Thanks in advance!
    johnoder's Avatar
    johnoder is online now Diamond
    Jul 2004
    Houston, TX USA
    18,476
    Post
    How did you come up with that? That BA for 90° would be for a .152 inside radius with .060 stock.
    Worst part about leaf brakes is that the stock, especially tough to bend stock, just "ooches" along under the clamp as the leaf tries to bend it. Ruins dimensions.
    I had to make a back stop blade for my brake, adjustable of course. Stock stayed put then.
    John
    Jun 2006
    Huntsville Alabama
    620
    Post
    our brake does have a stop adjustable with a push of a button on the display. My material isn't moving, this is not a whimpy leaf brake!
    Yes that is the correct inside radius, I just bent a piece of scrap to 90* and measured with radius gages.
    I am just asking how to apply this allowance, so that you can cut to exact length, and then run up against the stop on the brake and get a accurate part.
    johnoder's Avatar
    Jul 2004
    Houston, TX USA
    18,476
    Post
    If it is a two bend .06 part with .152 inside radii, the first leg will have (assuming part is dimensioned outside) .182 taken away from it and the other leg the same. The middle or lenght will be .364 shorter than outside.
    These dimensions are to bend zones, each of which occupies .286.
    So, if legs were 1" and overall bent lenght was 6", the dimensioning scheme would be:
    .818 from each end to commencement of bend zone, and 5.636 in the middle between the bend zones.
    The flat part before bending would be:
    .818+.286+5.636+.286+.818 for an overall of 7.844
    Note - this is all theoretical and assumes bend is equal on either side of neutral axis of the .060 thickness.
    Your machine/dies may not perform exactly this way, so make enough test pieces for you to see what needs to be done to satisfy both your requirements and its operating characteristics.
    If my math is off some this is your opportunity to say so
    Greg King is offline Aluminum
    Aug 2006
    Urbana, Ohio
    106
    Post
    This is the formula that I have used for years.
    Total Bend Allowance = (.01743 x Inside Radius) + (.0078 x Thickness) X Number of Degrees in Bend.
    Independent CNC Programmer
    www.ctcn.net/~3kings/
    Jun 2006
    Huntsville Alabama
    620
    Post
    Thanks alot! Still trying to figure out a couple of those numbers. Sorry for my ignorance, but where did .182 come from? First time getting into accurate sheetmetal work, and I hate not knowing how to do something.
    Also if you know of any books/websties that would be a help on this subject, that would be awesome!
    johnoder's Avatar
    Jul 2004
    Houston, TX USA
    18,476
    Post
    .182 comes from .152 radius and half of stock thickness. We are working along the neutral axis of the sheet metal
    dfw5914's Avatar
    dfw5914 is offline Stainless
    Apr 2006
    Fort Worth, TX
    1,276
    Post
    Exactly what type of bending equipment are you using, apron or press brake (even what model number)? What nose radius? It makes a big difference.
    It would also help to know how long the bend is and what hardness and alloy the SS is (this will relate to the suitability of the equipment).
    Most sheet metal working texts will have a chapter devoted to bend allowance calculations (with plenty of examples, charts, and illustrations) so getting the whole story here may take a while.
    Cavitation is offline Plastic
    Nov 2007
    Meeeeechigan
    14
    Post
    Hello ... (new here)
    ... sorry to jump right in with both feet and combat boots on but ...
    There is no need to make bend allowances for sheet metal ... (or even steel plate up to 1/4 inch thick .. even 3/8ths).
    ... what I mean is that ... if you bend a U shape ... with an "inside the U (upright legs) " at 10 inches ... and (2) 5" long legs measured from the inside of the bottom of the U ... then the total length of the piece of sheet metal would be be ....
    an even 20"
    ... been there done that - - many many many times ... and that IZ exactly how a fab shop will calc the piece length and bend layout also.
    dfw5914's Avatar
    Apr 2006
    Fort Worth, TX
    1,276
    Post
    Cavitation,
    Did you notice where he said +-.010?
  11. #11
    Jun 2006
    Huntsville Alabama
    620
    Post
    Ok that makes sense! Our machine is a 10 h.p. Atlantic hydraulic press break. The matl. is 304 SS. Not sure the nose R right now, I just measured the radius on the part after it was bent to 90*.
  12. #12
    WILLEO6709's Avatar
    WILLEO6709 is online now Diamond
    Nov 2001
    WAPELLO, IA USA
    4,109
    Post
    It depends a lot what you are bending, in what manner, and what has to come out the correct height. The third- half rule generally applies. Third half rule = the neutral axis will be 1/3 material thickness from the inside of the bend at up to 2 Material thickness bend radii, past that the neutral axis slides further out to 1/2 material thickness. Basically you dar the part " on the neutral axis". Figure bend lengths by finding arc lengths at neutral axis for bend allowance. add in adjusted straights for correct overall dim's, don't forget to adjust the holes in bent flanges if required. Cheating the bend radius is a quick way of final adjustment after trial bends.
  13. #13
    dfw5914's Avatar
    Apr 2006
    Fort Worth, TX
    1,276
    Post
    Rstewart,
    What are the dimensions of the flat and flanges?
  14. #14
    RickWGMkII is offline Senior Member
    Aug 2007
    SoCal
    327
    Post
    wow, all these answers & not much talk of flat length, mold length, set back & sight lines etc....
    How about letting us know the actual Rad of the bend?
    At least Greg has the correct math
  15. #15
    dfw5914's Avatar
    Apr 2006
    Fort Worth, TX
    1,276
    Post
    Rick,
    I think John covered all that, and the third post mentions actual measured bend radius.
  16. #16
    Aug 2007
    SoCal
    327
    Post
    oops, missed a line in the 3rd post [img]smile.gif[/img]
  17. #17
    dfw5914's Avatar
    Apr 2006
    Fort Worth, TX
    1,276
    Post
    I read the whole post three times before I noticed it
  18. #18
    JST's Avatar
    JST
    JST is offline Diamond
    Jun 2001
    St Louis
    10,847
    Post
    There is an actual formula for it, although in 28 years of dealing with sheet metal as part of product design, we basically did it the same as WillieO. That for the same 0.010 tolerances, where we had several tabs with holes that needed to line up with other holes on relatively complex bend-ups.
    Most all of our stuff was 16 and 18 ga with sharp inside bends.
    Now, I have a nice cheat sheet with the formula, as well as a bunch of tabulated examples. And I get into more large radius bending on 12 ga and larger. And ProE , Solidworks etc generally will figure the unfold for you.
  19. #19
    kilroyjones is offline Hot Rolled
    May 2005
    South Central Kansas
    591
    Post
    Where I work we do a lot of fabricating with 304 SS. Our shop tolerance is +/- .030 so our methods may or may not work for you.
    For bend deduction we use material thickness x2. So .060 mat'l would have a deduction of .120 We usually round that to .125 for easier figuring.
    If you have a U shaped part for example say 2"x4"x2" with the 2" being the flanges then add it all together 8". Now subtract .120 for each bend. 8" -.25 the flat pattern will be 7.75" Yes this is a very simple and quick method but we can easily hold a .030 tolerance.
    Another problem you might have is the wrong sized punch and die in your brake. For 16ga (.060) the V on the bottom die should be .5" wide at the top of the V. Quick and dirty method again, Thickness x8 for V opening on .25" thick or less metal. x10 for any metal thicker than .25"
    Using the formula that Greg posted I got .136 using a .060 radius. Where I rough figured .125
    I had never seen the formula Greg posted, it is very interesting. Holding a tolerance to .010 I can see where this formula would be more accurate. The next time we get a part thru the shop calling for precise hole locations, I will have to try this formula. Learn something new every day.
    Edited the post becuase I can't do basic math.
  20. #20
    Aug 2006
    Urbana, Ohio
    106
    Post
    FYI here is a site you guys may want to look at.
    http://www.sheetmetalguy.com/
