Best adhesive for magnets?
Results 1 to 16 of 16
    Mar 2006
    Cape Cod, Massachusetts
    4,829
    1133
    1877
    Default Best adhesive for magnets?
    I need to glue some rare earth magnets to mild steel rods, both .25" diameter. Same design as an eraser on the end of the pencil.
    They'll be holders for various small antiques. The magnets allow them to be mounted without mutilating them, and to be removed for inspection with a minimum of fuss.
    What's the best adhesive for this? Hardware store superglue hasn't lasted so long, even with careful cleaning of the surfaces. Is there a particular grade of superglue, or a flavor of Loctite that works well for this?
    JB weld has worked ok for larger magnets, but it seems a bit sloppy for .25"
    Any suggestions?
    Mar 2004
    Edison Washington USA
    10,153
    850
    4715
    I used to do this professionally, but boy, its been a long time.
    In the late 70's, I worked in a woofer factory, and we glued magnets to steel all day long.
    We used a loctite product, which required a particularly odd smelling oily activator, and the glue itself looked like honey. It dried to a translucent golden color. It was an anerobic, but not a super glue.
    Not sure, however, which loctite product that was- I used to order it in 5 gallon pails.
    I think JB weld is actually a pretty good solution- just mix it up on a piece of cardboard, and apply with a paper clip.
    Feb 2007
    Ridgefield, WA
    1,111
    134
    534
    We make 3/8" thick sliding shims from prehardened steel and bore holes in them to secure some rare earth magnets. We've always used JBweld and have used it for years. We simply leave about .004" clearance (just enough to squeeze the air out) and clean up the excess with alchohol before it cures. It works quite well.
    Nov 2008
    Madera county california usa
    2,057
    17
    469
    Default epoxy
    Epoxy labeled for metals should work fine.
    You did not state if the rods were the antique, if the magnet is on the display and is used to secure the item, then make pres fit holes in the rods for the magnet to be pressed into.
    Jan 2007
    1,219
    273
    405
    Quote Originally Posted by Sea Farmer View Post
    I need to glue some rare earth magnets to mild steel rods, both .25" diameter. Same design as an eraser on the end of the pencil...
    What's the best adhesive for this? ...
    Any suggestions?
    I would suggest Devcon High Strength 5 minute epoxy. I've had excellent results with this product for years, and have used it in in many professional metal/metal applications where I needed strength, durability with exposure to handling and attractive finish. Fast setup times...nice clear finish, easy to work with. My local hardware sells it fwiw, but they have a variety of packaging choices online. I usually get the (2) 4.5oz bottle pack
    http://www.devcon.com/prodfiles/pdfs/fam_tds_175.pdf
    http://www.amazon.com/Devcon-Minute-...7223658&sr=8-2
    Jan 2003
    Canada
    10,743
    4559
    2914
    Loctite 620 is what we used for magnets to steel. If you glue on aluminum 416 Loctite does alright.
    Apr 2002
    Webster, Ma. USA
    673
    9
    19
    Maybe 35-40 years ago, my snow blower wouldn't start. Found when pulled off the flywheel, the magmets had come "unglued" and re glued them with a regular 2 part epoxy. Good surface prep-clean all surfaces well- they are still firmly attached.
    Mar 2009
    Washington
    8,374
    5773
    10135
    Quote Originally Posted by SND View Post
    +1
    Thats what we use at work.
    Mar 2006
    4,829
    1133
    1877
    Thanks everyone. I have both JB Weld and Loctite 620 on hand, so it'll be one of those. I'll remember the devcon high-strength epoxy too, as I'm getting more of these projects.
    Feb 2005
    TYNE AND WEAR, ENGLAND
    2,497
    15
    Simply use a household flexible adhesive. I have a fair number in my workshop which have held or hold alloy rulers and plastic stuff without any bother.
    I was looking at a pair of these digital boxes to take cheap digital chinese scales. They are flexible glued to stick onto my lathe- in this instance.
    Really, it's as easy as that.
    Cheers
    Norman
  11. #11
    Nov 2005
    N E Florida
    1,996
    169
    Outboard motors use a glue to hold magnets inside flywheels that routinely handle 6000 RPM! If you can find out what it is. I know it is available because some older motors need to be re-glued because the magnets have shifted.
  12. #12
    Aug 2010
    Minnesota USA
    233
    38
    I'm a little surprised at the recommendation of J.B. Weld for super magnets. My experience was the disappointment for watching the "metal filled" epoxy creep out of position, along the magnetic field lines rather than stay in place. I guess that might be OK if you wanted to embed the magnet in epoxy.
    ken
  13. #13
    Mar 2007
    Milwaukee
    339
    262
    159
    I routinely use Loctite 331 it is a one part contact adhesive, cures fast works good.
    We also use an external mix two part epoxy that cures in 30 seconds (cant remember the name)
    True magnet bond adhesives cure very fast. Loctite publishes a magnet bonding guide.
    I wouldn’t use JB weld or anything with a filler, it will change the magnetic flux.
  14. #14
    Jul 2005
    Midlothian, Virginia
    2,610
    70
    222
    There's a link to the Loctite magnet bonding guide (PDF) at the bottom of this page:
    Henkel North America - Magnet Bonding Structural Adhesives
    The doc: http://www.henkelna.com/us/content_d...010_LT4914.pdf
  15. #15
    Oct 2010
    Ontario, Canada
    Cool Magnet Adhesive
    The best adhesive type is acrylic adhesives as they bond fast, bond metals well and are tougher which translates into impact resistance. The most common is an adhesive from Loctite called "Depend" where an activator is sprayed on one side and adhesive applied to other. Once mated it fixtures (ie only has to be clamped) in under 10 minutes. This is the type of adhesive used at OEM's for electric fan motors.
    That beign said if just doing one part many adhesives will work as people who have used 620 and Instant adhesives have commented.
  16. #16
    Mar 2006
    4,829
    1133
    1877
    I used Loctite 326, a 2-part adhesive. Works like a charm. I also used it to repair a broken antique cast iron tool handle, worked great for that.
    These pieces are subject to mild stress; as much force as a human hand can exert, but not a mechanical force. No temperature extremes. So far, so good, for this adhesive.
    The activator is the same Loctite activator I use for threadlockers -- 7649.
