Motorsports-X
Hot Rolled
- Nov 22, 2014
- Texas
I broke out my blake coax to quickly locate a couple centers and I notice that the arm was moving up and down almost 1/4"!! I don't mean the normal up and down movement of the body. it was centered so there was no body movement at all. that arm was moving like it was attached to a bent shaft.
So I got to checking. spindle, 0.0000 indicator run-out. brand new techniks holder, first check on the shoulder + .0015" TIR. hmm.. maybe that's it. check inside the collet seat to make sure. .0003TIR. (how can the shoulder be that far off? i digress, the holder is good.)
so put a collet in with a dowel pin, and I get about .0005 TIR.. about right considering the extra length from the collet seat. But then I put my blake coax in the collet leaving enough room to indicate the shaft, and now I'm throwing up almost .002TIR JUST BELOW THE COLLET? Then I check down on the metal piece just above the body and i get a little over .004TIR
WTH..this thing is brand new. (and over 400 bucks!) It sits in my box, and probably has been used less than a dozen times. never been crashed. I'm positive. (unless someone took it out my box and used it without my knowledge.)
So here-in lies the problem. I just drilled about 400 bolt holes using that thing to find center. Thankfully there is .020 positional tolerance, but it appears to me that any error/bend in the shaft will be multiplied at the indicator, since you now have to move the machine out of position to offset the bend. (should be a 1:1 move I beleive.) Who knows how much that value was, but I'm putting it around .008 out of position. But I yet to measure the part. This explains so much why a couple jobs I did in the past, just "felt" like they were ever so slightly off, even though it was just barely or impossible to measure.
Obviously a zero set is going to be better because you are directly linked to the spindle axis, but what do you guys use when you cant get in there. or you don't have enough room to spin your indicol. I guess I could use my 3d Taster to touch the sides of the hole. do that twice per hole and your gonna be very accurate. but even then, sometimes its to big. So throw some years of experience at me. what Have you guys found to be the best. and has anyone experienced on of these blakes to be bad almost right out of the box? (i should of checked it. out of warranty now)
