Best material for Allen wrench
Bassbum2
Jan 13, 2011
Massachusetts
I would like to make a 2.5mm T handle Allen wrench that is about 16" long, only the working end needs the hex to be machined, what is the best material for this application?
Russell
Cut off part of an allen wrench and silver solder or braze or solder or press or -any way you can hold it in to an extension. Than add a cross pin or bar on top. Don,t waste yor time machining one.
It does have to be no bigger than the original dimensions of a 2.5mm allen wrench. It will have a fair amount of torque on it, will the silver solder hold up and would the heat soften the Allen wrench? If I machine one, I only need to machine about .5" of the end.
Russell
You are going to be seriously bummed out when you break the tip off in the bottom of the hole.
If the tip did break off it is accessable as the job can be done with two Allen wrenches, one normal and one stubby, one that is 16" just makes a 45 minute job only take 20 minutes.
Russell
Best material would be the drawn and heat treated stock the majors use for their wrenches. For a one off with the major diameter limitation you specify with only the end machined to a hex the quickest and most available stock to size is drill rod. A big plus is it can be heat treated, it's tool steel.
O1 or W1 would be good for the first 10-15 minute prototype, it's available off the shelf in the size you need for a dollar or two. Heat treat the hex end and give it a try. Or not, perhaps it would be good enough without heat treatment. The entire tool could be heat treated if required for higher torque strength. (It won't make it twist less.)
Torque requirement would be useful, that along with the diameter restriction would have added to the original request to get a good recommendation.
DaveE907,
I will see if I can get the actual torque specs. I used to have an allen wrench that would reach almost to the last of 16 bolts and at only 15" it would put a pretty good twist in the wrench.
S_W_Bausch,
A 14" 1/4 drive extension would be to to big in diameter and and too short. I was hoping to use a piece of .125" of the recomended material.
Russell
Russell,
Is there enough material in a standard "loop-handle" wrench to experiment with whatever steps are necessary to straighten it out? Probably localized heating at the handle end, along with some degree of re-hardening after adjustment... At least if it ends up breaking off, it'll be up at the end closest to the outside world, and potentially within reach of a magnet.
Chip
Allen wrenches are made from S2 steel. Recent experience with a stuck 4mm hex head
set screw suggests that a 16" long 2.5M allen wrench is going to twist a lot making
delivered torque to the head something you would have to compensate for. The allen
wrenches are not spring steel and may remain twisted to some degree. Allen wrenches
need to be tough, not 'hard'.
T Handles
At work we use 17/4PH stainless heat treated at 480 degrees C for 1 hour with an air cool to H900 condition. We use these for for 3.5 mm hex head wrenches and yet still have to have a torque limited T handle limiting them to no more than 8 Nm or they snap very nicely in the socket...
Here is one of many I have made:
Drill a hole in a piece of round stock for a cut off piece of allen wrench to slip into. Cross drill and tap for a 10-32 setscrew (Drill and tap for two if you are really reefing on the T handle). Cross Drill the other end about 1/4" for a 6 to 8 inch long piece of 1/4" drill rod. Another setscrew on the T end secures the drill rod.
