Best material for Allen wrench
Results 1 to 18 of 18
    Jan 2011
    Massachusetts
    149
    Default Best material for Allen wrench
    I would like to make a 2.5mm T handle Allen wrench that is about 16" long, only the working end needs the hex to be machined, what is the best material for this application?
    Russell
    Feb 2008
    Illinois
    1,188
    51
    344
    Cut off part of an allen wrench and silver solder or braze or solder or press or -any way you can hold it in to an extension. Than add a cross pin or bar on top. Don,t waste yor time machining one.
    Mar 2011
    Denver, CO USA
    11,178
    41
    4966
    Add a bit to this...
    T-Handle Bit Driver (no welding)
    Unless you really need the overall diameter to be 3mm...then it gets trickier.
    Jan 2011
    Massachusetts
    149
    It does have to be no bigger than the original dimensions of a 2.5mm allen wrench. It will have a fair amount of torque on it, will the silver solder hold up and would the heat soften the Allen wrench? If I machine one, I only need to machine about .5" of the end.
    Russell
    Mar 2011
    Denver, CO USA
    11,178
    41
    4966
    You are going to be seriously bummed out when you break the tip off in the bottom of the hole.
  6. Likes cgb2 liked this post
    Jan 2011
    Massachusetts
    149
    Quote Originally Posted by Miguels244 View Post
    If the tip did break off it is accessable as the job can be done with two Allen wrenches, one normal and one stubby, one that is 16" just makes a 45 minute job only take 20 minutes.
    Russell
    Sep 2005
    South Carolina USA
    4,498
    2154
    1304
    OR, it sure is going to sting (like a cracked bat), when the screw breaks loose. I hate any T-hex wrenches for that reason.
  9. #8
    Mar 2011
    Denver, CO USA
    11,178
    41
    4966
    Quote Originally Posted by Davis In SC View Post
    The plastic handle ones are OK...but these SOBs hurt.
    Amazon.com: Oregon Replacement Part SET, T-HANDLE ALLEN WRENCH # 42-480-0: Patio, Lawn & Garden
  10. #9
    Sep 2007
    Spanish Springs, NV
    2,367
    155
    280
    Best material would be the drawn and heat treated stock the majors use for their wrenches. For a one off with the major diameter limitation you specify with only the end machined to a hex the quickest and most available stock to size is drill rod. A big plus is it can be heat treated, it's tool steel.
    O1 or W1 would be good for the first 10-15 minute prototype, it's available off the shelf in the size you need for a dollar or two. Heat treat the hex end and give it a try. Or not, perhaps it would be good enough without heat treatment. The entire tool could be heat treated if required for higher torque strength. (It won't make it twist less.)
    Torque requirement would be useful, that along with the diameter restriction would have added to the original request to get a good recommendation.
  11. #10
    Jan 2010
    Indianapolis, Indiana, USA
    5,475
    2426
    926
    I would consider starting with a 1/4 inch drive (ratchet) extension, removing the driving (male) end and grinding a hex onto it.
    They do exist:
    Proto 14 inch 1/4 drive socket extension used | eBay
  12. #11
    Jan 2011
    Massachusetts
    149
    DaveE907,
    I will see if I can get the actual torque specs. I used to have an allen wrench that would reach almost to the last of 16 bolts and at only 15" it would put a pretty good twist in the wrench.
    S_W_Bausch,
    A 14" 1/4 drive extension would be to to big in diameter and and too short. I was hoping to use a piece of .125" of the recomended material.
    Russell
  13. #12
    Sep 2010
    Oklahoma City, OK
    3,290
    567
    1447
    Well when you get it figured out be sure to use it to smack the guy who put that tiny screw i such a deep hole.
  14. #13
    Dec 2007
    Central Ohio USA
    3,581
    45
    1595
    Russell,
    Is there enough material in a standard "loop-handle" wrench to experiment with whatever steps are necessary to straighten it out? Probably localized heating at the handle end, along with some degree of re-hardening after adjustment... At least if it ends up breaking off, it'll be up at the end closest to the outside world, and potentially within reach of a magnet.
    Chip
  15. #14
    Feb 2004
    Bham, AL
    756
    46
    Allen wrenches are made from S2 steel. Recent experience with a stuck 4mm hex head
    set screw suggests that a 16" long 2.5M allen wrench is going to twist a lot making
    delivered torque to the head something you would have to compensate for. The allen
    wrenches are not spring steel and may remain twisted to some degree. Allen wrenches
    need to be tough, not 'hard'.
  16. #15
    Dec 2009
    UK
    54
    8
    Default T Handles
    At work we use 17/4PH stainless heat treated at 480 degrees C for 1 hour with an air cool to H900 condition. We use these for for 3.5 mm hex head wrenches and yet still have to have a torque limited T handle limiting them to no more than 8 Nm or they snap very nicely in the socket...
  17. #16
    May 2002
    South Central PA
    12,674
    1665
    2836
    Quote Originally Posted by sch View Post
    Allen wrenches need to be tough, not 'hard'.
    Do you know the correct HT spec for them?
  18. #17
    Feb 2006
    so cal, usa
    444
    108
    99
    I'm wondering if you knewMcMaster sells such a wrench, with short, replacable tips?
  19. #18
    Jan 2008
    Mountains of Washington State, USA
    410
    123
    Here is one of many I have made:
    Drill a hole in a piece of round stock for a cut off piece of allen wrench to slip into. Cross drill and tap for a 10-32 setscrew (Drill and tap for two if you are really reefing on the T handle). Cross Drill the other end about 1/4" for a 6 to 8 inch long piece of 1/4" drill rod. Another setscrew on the T end secures the drill rod.
