Hello, I asked for opinions of a Clausing 1300 lathe about a week ago and got back very positive answers. The machine I am looking at is in very good condition but has been sitting in the owners unheated barn (I'm in Maine) for about 4 years. The owner said everything worked fine but it wasn't powered up. I told him of my concern about the vari-speed and he didn't know about it, but it had never been a problem for him. My question is, does the 1300 have the same problematic variable speed as the 5900 series has, or is it a different set-up?
The owner called me this evening and said he did hook it up to run it, and the vari-speed was acting up. When he moved the lever above 800 rpm it worked fine, but when he went below that the lever would spring back to the 800 position, and would not change the speed. Does this sound like the delrin bushing problem, if it has them, or could this be leaking, low fluid level?
I'm going over to check it out tomorrow. Some back ground on the machine: he said he didn't change speeds very often but every once in a while he would run the speeds up and down just to give them a work out. What are the symptoms of a delrin bushing problem?
This is a nice machine and I'd like to get it but I'm not sure if this is a serious problem or not. Thanks in advance for your help. Jeff
